Re: Anyone make E body side glass guide hairy felt?
[Re: 71TA]
#250032
03/13/09 08:32 AM
03/13/09 08:32 AM
Posts: 1,756 London, England
Gavin
London, England
Which is what year? Are these from E bodies? Are the other "bodies" the same material?
Also looks like theres a backing on the hair ones that wrap around the bracket.
Is that hair one in the one picture removed from the bracket? If so can you lay it out flat and take a picture and some measurements? I found a company that ACTUALLY makes the stuff but they have MASSIVE minimums.
Also how "tall" is the hair on each? Have a set of calipers to measure accurately?
Jim, yes these are all for a Challenger. The fuzzy ones are off my 71, the hairy ones I can't be sure - they were either also off my 71 or off the donor doors which were not 71 (don't know if they were 70, 72, 73 or 74 - I suspect 70)
On BOTH types the backing material wraps around the brackets - you can see it on the fuzzys in the pic if you look carefully
Yes I still have those and certain I have some material removed from the brackets, I am happy to take some pics of that and measurements too as soon as I get a chance (hopefully tonight!)
[Re: 71WMFJ6]
#250034
03/13/09 01:03 PM
03/13/09 01:03 PM
Posts: 12,422 Warren, MI
71TA
Warren, MI
If anyone can contribute a picture (with a scale besise the part for scaling refrence) I'd appreciate it. Also what year and model (I know there are other body styles than Cuda's and Challengers )
[Re: 71WMFJ6]
#250040
11/23/09 02:58 PM
11/23/09 02:58 PM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
Does anyone know if the material is available at a local source? Walmart, craft supply,etc? I have a 70 Challenger in real need of these updated! Thanks Brad
[Re: burdar]
#250048
07/18/11 09:22 PM
07/18/11 09:22 PM
Challenger 1
Cincinnati, Ohio
My 73 Challenger has them. Yours should too.
Yup, that's why your glass is scratched and why your glass rattles when you close your door. Got to use them. Easy to glue something on there that is better than glass on metal.
