MSD 6013 Hemi 6
#2498769
05/21/18 08:31 PM
05/21/18 08:31 PM
Posts: 34 wa.state
raceadodge
wa.state
I have installed a 5.7L Gen-III Hemi that is stroked out to 392, with the MSD Hemi-6 ignition box and harness #88864, basically the same combination as TripleThreat, who is a member of this board. I have been trying to start it without success, and it has been back-firing and popping through the carburetor and exhaust. We even tried working with MSD and switching the ignition box, with no change.
I then started looking at part numbers on the build sheet that I received from my engine builder, and discovered that he installed a 58-tooth reluctor wheel on the crankshaft. I was told by TripleThreat and another person on Facebook that this box will not work with this reluctor wheel, that it should be a 32-tooth reluctor wheel, instead.
I have looked everywhere I can think of on the internet for official information on this, and so far I haven't had any luck. If anyone has any information or can post a link, I would appreciate it.
P.S., MSD has not been any help with this question.
Re: MSD 6013 Hemi 6
[Re: raceadodge]
#2499438
05/23/18 12:32 PM
05/23/18 12:32 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Thank you, that actually does help. I do have the correct ignition box and harness for my application, but the crankshaft that was installed was for an '09 and newer engine. Hopefully just the reluctor wheel itself can be replaced so the bearing clearances won't have to be re-checked & the rotating assembly won't have to be re-balanced. Crank has to come out. balancing won't be an issue. Call MSD maybe you can make it work with the 52 wheel
Re: MSD 6013 Hemi 6
[Re: raceadodge]
#2500916
05/27/18 08:15 AM
05/27/18 08:15 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
I'll lay you odds 20 to 1 that your Exhaust valve hit the top of the bore on #5 and #7 , and I wouldn't be surprised if the others have nicks in them from touching.
ThiTke heads on a 5.7 block with less than 3.957 bore are asking for issues. both performance and physical. I did a 377ci (3.922 X 3.90) back in March, I had to notch the bore back to get good clearance and better power #s than stock Eagles on that build. used the 6.1 Head gaskets notched the bores on both Intake and Exhaust side, did both sides back to the gasket and down to the top ring travel. On a stock 04 5.7 block we test fitted the THitke heads and on that block, #1,3,5 and #6 exhaust valves physically hit the block....needless to say that block wasn't used for this build.
that was my result
PS, I guess I don't need to chime in on the tone ring, you know by now you need the 32 tooth.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
Re: MSD 6013 Hemi 6
[Re: ric3xrt]
#2501205
05/28/18 01:30 AM
05/28/18 01:30 AM
Posts: 34 wa.state
raceadodge
wa.state
Thank you for that reply. I wasn't quite sure what to think about the exhaust valves bent. I would think because of the size, the intakes would be more susceptible. Yes, this has turned into a cluster. I certainly hope my builder steps up and makes it right.
