V10 rod bearing swap. #2499194
05/22/18 08:13 PM
05/22/18 08:13 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
In the truck.It makes a noise around 2100 rpm.I think it might be a loose bearing.Think it would be OK to change it or not.Anyone have success swapping bearings and did it last.
Re: V10 rod bearing swap. [Re: chargers777] #2499324
05/23/18 01:48 AM
05/23/18 01:48 AM
ND
dodgedon Offline
dodgedon  Offline
ND
You may remember posting on my same issue about 4 months ago. So far my rattle is completely gone. If your V10 is like mine, I think you will find that the crank journal is not round. I wanted to do the same thing but it just didn't "feel" right. So I pulled the motor out and had the crank checked. It was oval to the point that it could not be turned. I just dropped a complete crank kit in. It runs and sounds like a completely new motor.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: V10 rod bearing swap. [Re: chargers777] #2499756
05/23/18 11:49 PM
05/23/18 11:49 PM
Nashport, OH
Nashport, OH
Anyone have success doing this swap in the vehicle.
