I'm curious if anyone has messed with 90s-era power steering pumps on small blocks.
I'm using a ZJ Grand Cherokee pump on my car. Is anything known about the internals of these things? It'd be great if I could reduce my pressure in a similar way as the older Saginaw pumps. The option of effortless one-finger cornering is getting weird.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
