RB hydraulic roller cam
#2498797
05/21/18 10:04 PM
05/21/18 10:04 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I am thinking about putting a hydraulic roller cam in my 500" Indy headed -1 motor. It currently about 11:1 compression with a solid roller cam around .630 lift. Who has the best cam and lifters since this will be my first hyd roller motor?
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: RB hydraulic roller cam
[Re: 65 Hemi]
#2498961
05/22/18 10:08 AM
05/22/18 10:08 AM
Posts: 13,345 Marion, South Carolina [><]
an8sec70cuda
I haven't assembled it yet, but Dwayne Porter (fast68plymouth) spec'd a hydraulic roller for my dad's 540" hemi project and we went w/ a set of Scorpion hydraulic roller lifters. I've been VERY pleased w/ every other cam/head/valvetrain combo Dwayne has helped me with...no reason to think this won't work great.
[Re: Mopar Guy]
#2499144
05/22/18 05:25 PM
05/22/18 05:25 PM
65 Hemi
San Diego CA
It will be 100% street driven. It getting Holley Sniper 4500 EFI and AC.
Doug
[Re: 65 Hemi]
#2499183
05/22/18 07:37 PM
05/22/18 07:37 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I went with the Morel High rpm versions, $940.00 from Hughes, they work good so far, car ran 11.33 @ 121, 4100 lb Charger, no tuning yet, they are a little noisy when cold, you can adjust them .020 from bottoming out of the plunger, & they also recommend no heavier than 5-40 oil, I am running 10-40 Lucas racing oil with no problems. pulls great over 6200. my car is a street car.
[Re: Cab_Burge]
#2499216
05/22/18 09:07 PM
05/22/18 09:07 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
If it was me building your motor I would select a tight lash solid roller cam with a really good set of bushed solid roller lifter and matching valve springs, pushrods and so on. Set them once when cold and again after running the motor long enough to get the oil and coolant temps. up to or above 160 F and reset the lash once more and enjoy the higher RPM of the solid roller cam and lifters with those good heads I'm not a big fan of hydraulic roller lifters, yet, for either Mopar BB or 426 Hemi motors yet due to past bad experiences with hydraulic roller lifters in them This right here!!!!👆👆
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: CSK]
#2499248
05/22/18 11:10 PM
05/22/18 11:10 PM
Posts: 4,310 Prospect, PA
BSB67
Prospect, PA
I went with the Morel High rpm versions, $940.00 from Hughes, they work good so far, car ran 11.33 @ 121, 4100 lb Charger, no tuning yet, they are a little noisy when cold, you can adjust them .020 from bottoming out of the plunger, & they also recommend no heavier than 5-40 oil, I am running 10-40 Lucas racing oil with no problems. pulls great over 6200. my car is a street car. do you think the lifter is operating like a hydraulic, or a solid?
[Re: BSB67]
#2499299
05/23/18 01:01 AM
05/23/18 01:01 AM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
We use Gaterman and Topline and have been very pleased with their performance. Brian
Brian Hafliger
[Re: BSB67]
#2499316
05/23/18 01:38 AM
05/23/18 01:38 AM
CSK
Pattison Texas
I went with the Morel High rpm versions, $940.00 from Hughes, they work good so far, car ran 11.33 @ 121, 4100 lb Charger, no tuning yet, they are a little noisy when cold, you can adjust them .020 from bottoming out of the plunger, & they also recommend no heavier than 5-40 oil, I am running 10-40 Lucas racing oil with no problems. pulls great over 6200. my car is a street car. do you think the lifter is operating like a hydraulic, or a solid? more like a solid,but with dampening for the roller, no lash, so hopefully they will last longer on the street than all the horror stories of solids failing from street use, I said you can adjust them .020 from the bottom, mine are not done that way, mine are 1/2 turn from zero.
[Re: CSK]
#2499318
05/23/18 01:41 AM
05/23/18 01:41 AM
Posts: 4,663 Wichita
GY3
Wichita
I run Howards.
4700 miles so far and lots of strip abuse. Only rated to 6500 rpm. I have the limiter at 6400.
[Re: GY3]
#2499330
05/23/18 02:10 AM
05/23/18 02:10 AM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
I run Howards.
4700 miles so far and lots of strip abuse. Only rated to 6500 rpm. I have the limiter at 6400. Gaterman supplies Howards with their link bar lifters for most applications.
Brian Hafliger
[Re: Cab_Burge]
#2499460
05/23/18 01:27 PM
05/23/18 01:27 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
If it was me building your motor I would select a tight lash solid roller cam with a really good set of bushed solid roller lifter and matching valve springs, pushrods and so on. Set them once when cold and again after running the motor long enough to get the oil and coolant temps. up to or above 160 F and reset the lash once more and enjoy the higher RPM of the solid roller cam and lifters with those good heads I'm not a big fan of hydraulic roller lifters, yet, for either Mopar BB or 426 Hemi motors yet due to past bad experiences with hydraulic roller lifters in them Good advice given my experience with hydraulic rollers. Initially, my valve springs were not set-up properly and likely weakened quicker than normal too though. The valve train harmonics really beat up my rockers as a result of it. Even with all that going on the motor spun out 684 hp at around 5400 rpm before the springs lost control of the valvetrain. Cab, thanks for the tip on checking the lash again with the motor warmed up. I haven't done that yet on my new solid roller valvetrain, but I will. Dwayne Porter sure nailed the latest combo in my case too. My motor is running stronger than ever even with 2 full points less compression and burning California pump swill. I haven't dynoed it yet, but it sure runs a lot smoother now with the solid roller valvetrain.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: BradH]
#2499923
05/24/18 12:00 PM
05/24/18 12:00 PM
65 Hemi
San Diego CA
I would like to keep the RPMs in the 3-6k range since that is a 100% street can that will never see the track again. I have other race cars when I have the urge. I will put between 10-12k miles per year on this car and drive it to work most days when the weather permits. I am looking for the reliability and about 600-650HP
Doug
[Re: 65 Hemi]
#2499935
05/24/18 12:20 PM
05/24/18 12:20 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I have a problem with understanding why someone needs a 650 hp motor that is only going to be street driven and never raced and wants to be reliable???? That is a lot of strain on parts to make that much power to be pounded on at low speeds for bragging rights. lie!!! and leave it stock. That's my .02. Don't get me wrong I like a lot of hp but i use it for what intended.
JAKES AUTOMOTIVE
[Re: JAKE68]
#2499953
05/24/18 01:09 PM
05/24/18 01:09 PM
65 Hemi
San Diego CA
Lol. Well I didn’t say I wouldn’t drive hard! The reason I have is I have 3 other race cars and miss a little street action. I already had it built with a world block, decent parts and -1 heads and drive it maybe 500 miles per year. So instead of building a new motor I should use the parts I have. I would think it should be possible to make 600hp out of a 500” motor and be very reliable.
Doug
