Coolant Question...
#2498732
05/21/18 07:06 PM
05/21/18 07:06 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
I have the 408 out of the demon, I don't like what I see in the aluminum radiator, Was curious if the new Mopar HOAT coolant, which I have a lot of from work, will this be better than standard green or that Pink stuff? THis stuff is already pre mixed and seems to hold up great in the Diesels and in the Hemis, Just wondering if I flushed the radiator out really well, and the heater core if I could use it. We do a water pump recall on the cummins and mopar allots 1 gallon of pre ixed coolant to every recall, and I use my vac to suck the coolant out and put it all back in so I never use the coolant and have like 10 gallons the parts manager said to "get it the heck outa here"
lol
Sooooo, in lies my question
Re: Coolant Question...
[Re: Moparnut426]
#2498758
05/21/18 07:56 PM
05/21/18 07:56 PM
RapidRobert
I dont have an answer but I would try Googling "mopar hoat coolant" & see if anything relevent pops up.
[Re: Moparnut426]
#2498808
05/21/18 10:28 PM
05/21/18 10:28 PM
Posts: 11,526 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Never had an issue with the green stuff and distilled water. If this car is not air conditioned or subject to freezing temps, I would just use distilled water and an anti-rust/water pump lubricant in it. Google electrolysis in cooling systems if you're not familiar with it.
[Re: Moparnut426]
#2499113
05/22/18 04:06 PM
05/22/18 04:06 PM
Posts: 4,457 Washington
madscientist
Washington
I use Evans and don't look back. It's expensive but worth it.
