Jeep Grand Cherokee rear shock thump #2498612
05/21/18 12:39 PM
05/21/18 12:39 PM
Pikes Peak Country
TC@HP2 Offline OP
TC@HP2  Offline OP
Pikes Peak Country
It seems the second generation Grand Cherokees, WJ, have a reputation for rear shocks to start thumping around after the OEM dampeners are replaced with aftermarket units. Common fix is to replaced the factory stepped bolts with a straight shank M12x1.75. Tried this in mine with no success. Even with the consistent shank diameter, there is <1mm of play between the
bolt and bushing that allows the clunking to continue as the suspension cycles. As a temp fix, I wrapped a layer of duct tape around the stock bolts to absorb the hit. Its working so far but eventually will get pounded out and the clunking will return.
Anyone found a successful and consistent fix for this? I've seen a few kits out there, but they are simply a steel sleeve with the aforementioned M12x1.75 full shank bolts. My replacement shocks already have a steel sleeve.
Re: Jeep Grand Cherokee rear shock thump [Re: TC@HP2] #2498800
05/21/18 10:07 PM
05/21/18 10:07 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Tighten them up
Angry white pureblood male
Re: Jeep Grand Cherokee rear shock thump [Re: TC@HP2] #2499179
05/22/18 07:33 PM
05/22/18 07:33 PM
Pikes Peak Country
TC@HP2 Offline OP
TC@HP2  Offline OP
Pikes Peak Country
Okay. Is there a spec number I'm shooting for or just crank em tighter?
Probably need to get a FSM for this so I have those types of details.
Re: Jeep Grand Cherokee rear shock thump [Re: TC@HP2] #2499998
05/24/18 03:03 PM
05/24/18 03:03 PM
Pikes Peak Country
TC@HP2 Offline OP
TC@HP2  Offline OP
Pikes Peak Country
Found out torque is a whopping 80#. I maybe had these cinched down to 30. So, I'll crank up the value and evaluate.
