Which ATF to use?
#2498466
05/21/18 12:38 AM
05/21/18 12:38 AM
340clone
I need to ad about a quart of auto trans fluid after losing some due to a radiator and trans line change. Car has BB 727.
I'm not sure what the PO used, but almost positive it's not synthetic. I'd bet it's either Dex/Merc, or less likely ATF+4. He doesn't remember.
So, assuming that it's either of the two, what would it be safe to top it off with? I can't seem to get a straight answer from the side of any bottle or from the internet on what the compatibility of either type of fluid is. All conflicting answers...
Really don't want to drop the pan unless I have to for a full fluid change. What are my options for topping off?
Re: Which ATF to use?
[Re: 340clone]
#2498548
05/21/18 10:19 AM
05/21/18 10:19 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
No way to tell really.
If it is a restoration or daily driver I would guess Dex/merc.
If it is a street/strip or otherwise modified I would guess Type F.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: 340clone]
#2498553
05/21/18 10:30 AM
05/21/18 10:30 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
I'd use Type F. No problems mixing trans fluids anyway.
[Re: 340clone]
#2499309
05/23/18 01:27 AM
05/23/18 01:27 AM
Posts: 954 Chicago
PurpleBeeper
Chicago
Ummmmm....my step father (40+ yr mechanic) would disagree. He always told me "don't mix trans fluid or you might get foaming...pick one & stick with it" He most certainly meant "don't mix Dextron II with Type F" based on his age. I've never tested it, but I've always followed his advice.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2499647
05/23/18 08:01 PM
05/23/18 08:01 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
He always told me "don't mix trans fluid or you might get foaming. Nonsense, all modern ATF's have anti-foaming additives. BTW, my favorite fluid is a 50/50 blend of type F and Dexron.
[Re: 340clone]
#2499814
05/24/18 01:56 AM
05/24/18 01:56 AM
340clone
So I had some Dex/Merc handy so I added it a pint at a time while idling in neutral. I added a total of 1 quart to get the level to the full line on the dipstick. After taking the car for a spin, the level was about a quarter inch above full. Guess it wasn't hot enough when I was adding fluid.
Is a little overfill going to hurt? Should I remove some?
[Re: 340clone]
#2500059
05/24/18 05:05 PM
05/24/18 05:05 PM
John_Kunkel
Rio Linda, CA
A little under is better than a little over.
[Re: 340clone]
#2500061
05/24/18 05:23 PM
05/24/18 05:23 PM
Posts: 15,827 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
This one is always a controversy.
I vote Dex/Merc because trans expert who's had a shop in my area for decades advised me to use Dex/Merc.
Facts are stubborn things.
[Re: John_Kunkel]
#2500162
05/25/18 12:28 AM
05/25/18 12:28 AM
340clone
A little under is better than a little over. I have to change the speedometer gear, so I can remove some fluid then. Thanks!
