Find fuel sender '71 C body POLICE 5/16" out AND with return #2497775
05/19/18 02:05 AM
05/19/18 02:05 AM
Western US
Furious440 Offline OP
Western US
This is my dilemma:
I have a 1971 Fury I 440 HP police car that needs a new fuel sending unit. The original has a 5/16" fuel outlet and 1/4" fuel return nipple. OEM part number is 3621608. This is a four vent fuel tank system with E.C.S.
The only senders I find available for C body do not have a return line shruggy For example part number 3420849.
Does anyone know if my part is available? help
Thank you in advance for your reply.
Re: Find fuel sender '71 C body POLICE 5/16" out AND with return [Re: Furious440] #2498022
05/19/18 10:30 PM
05/19/18 10:30 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
If not available, adding the return is no big deal.
Angry white pureblood male
Re: Find fuel sender '71 C body POLICE 5/16" out AND with return [Re: Furious440] #2498123
05/20/18 06:38 AM
05/20/18 06:38 AM
WA
tman Offline
tman  Offline
WA
There are places that can rebuild your sending unit. Just do a search and there are several choices. I don't know who is good though. You can only hope they are all good.
Re: Find fuel sender '71 C body POLICE 5/16" out AND with return [Re: Furious440] #2498262
05/20/18 03:08 PM
05/20/18 03:08 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Have you run the part number through the dealer? You'd be surprised some times.
Re: Find fuel sender '71 C body POLICE 5/16" out AND with return [Re: Furious440] #2498339
05/20/18 07:02 PM
05/20/18 07:02 PM
md
mopars4ever Offline
mopars4ever  Offline
md
My 71 parts book only shows 2 part numbers. One for car 3420849 and one for station wagon 3420850. Police has a special section and it calls for the part number 3621608 as you listed. I checked parts voice and none showed up.
I have a volare that has a two model year only sending unit that is hard to find. I was thinking of removing the gauge portion of a nos sending unit and switching it with the old one. I wonder if anyone has done that before? I can`t remember how it is attached to the tube.
Re: Find fuel sender '71 C body POLICE 5/16" out AND with return [Re: mopars4ever] #2498543
05/21/18 10:00 AM
05/21/18 10:00 AM
moparx Offline
moparx  Offline
i have re-tubed sending units a few times, using 3/8 and 1/2" tube. i silver soldered the gauge unit to the tube. worked very well.
beer
Re: Find fuel sender '71 C body POLICE 5/16" out AND with return [Re: Furious440] #2498556
05/21/18 10:35 AM
05/21/18 10:35 AM
md
mopars4ever Offline
mopars4ever  Offline
md
moparx, thanks
Re: Find fuel sender '71 C body POLICE 5/16" out AND with return [Re: Furious440] #2498885
05/22/18 01:06 AM
05/22/18 01:06 AM
Western US
Western US
Thank you everyone for your advice! bow
I have scoured the internet and can not find the correct part.
I am tempted to solder in the additional return line to my NOS C-body sender. But I am afraid that the heat required would ruin the plastic insulators for the wire, not to mention ruin the coating.
I am looking in too sending the old unit out for restoration. But it is terribly rusty as it sat in bad gasoline for 11 years! I did get a new tank, pad, rubber hoses, clamps, etc.
Does anyone have an opinion about adding a fuel bulkhead connector from Earl's or the like???
Re: Find fuel sender '71 C body POLICE 5/16" out AND with return [Re: Furious440] #2498889
05/22/18 01:12 AM
05/22/18 01:12 AM
Western US
Western US
BTW:
Correction, the return line is 5/16" and not 1/4" as stated in my first post.
Thank you.
Re: Find fuel sender '71 C body POLICE 5/16" out AND with return [Re: Furious440] #2498924
05/22/18 05:07 AM
05/22/18 05:07 AM
WA
tman Offline
tman  Offline
WA
Should include a photo of your sending unit. If its rusted, you might be able to get some of that Rust remover liquid where you just soak the part for a day. Unless the tubes are rusted through and through. You have a hard part to find there.
Re: Find fuel sender '71 C body POLICE 5/16" out AND with return [Re: Furious440] #2499407
05/23/18 11:30 AM
05/23/18 11:30 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Here is one source. I've ordered parts from them with no issues though I've not used their rebuilding service.
http://tristarrradiator.com/
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
