#2495660 - 05/13/18 05:59 PM Edelbrock Victor 4500 for RB question
tex013 Offline
Loc: Sydney,Australia
Recently bought 1 for my 505 . And started port matching . I have CNC stealths .
It would seem these are cast as for max wedge and stock port , just not opened up .
2 questions
- looks like I will have to remove across top of ports to fit rocker covers . I have Mopar cast type .
- I may have to do the same across bottom of ports as well
Is this correct ?
I have seen in the TF270 thread , after I started that the port / bolt holes appear to be raised 0.050 in manifold face .
I am using the Trickflow valley plate , Andy's batwings and Superformance gaskets
thanks ,
Tex
Edited by tex013 (05/13/18 05:59 PM)
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
#2495946 - 05/14/18 11:35 AM Re: Edelbrock Victor 4500 for RB question [Re: tex013]
fast68plymouth Offline
Loc: So. Burlington, Vt.
You have all the parts in front of you....... I would think it's pretty obvious what needs to be removed.
I'm not sure how the size and placement of the cnc'd port openings for MW stealths is compared to OE MW heads, but compared to the std ports..... The MW port openings go higher and lower than the std ports.
Edit: after re-reading your post, I guess I'm unclear exactly what you have going on there or what you're trying to do.
You mention the TF270 heads, which are raised runner MW heads..... But then you also talk about the batwings, which are for non-raised runner std port heads.
Description: MP MW gasket on 518 head
Description: MP MW gasket on stealth head being opened up to use OE MW intake
68 Plymouth Satellite, 383, stock 906's, 3550lbs, 11.18 @ 123, 1.51 60'
WD- Comp Cams / Indy Cylinder Heads
#2496142 - 05/14/18 06:28 PM Re: Edelbrock Victor 4500 for RB question [Re: tex013]
tex013 Offline
Thanks Dwayne
I have stock port size with the CNC stealth
So time to grind more
I may have been unclear - I meant across top and bottom on external of gasket , not the actual port opening . Where you can see bearing blue on picture
Tex
Edited by tex013 (05/14/18 06:33 PM)
New best MPH 130.32
#2496388 - 05/15/18 10:04 AM Re: Edelbrock Victor 4500 for RB question [Re: tex013]
I put an Indy 440-2 on some rpm heads years ago.
I used an .080" thick piece of aluminum for a valley plate, and had to remove quite a bit off the lower edge of the manifold, and double gasket it, to make it fit.
But the heads and intake were MW size.
#2496578 - 05/15/18 05:39 PM Re: Edelbrock Victor 4500 for RB question [Re: tex013]
tex013 Offline
ok thanks
yes will hopefully test fit this afternoon
1st though is pull motor/gearbox out of E Type Jag
Tex
New best MPH 130.32
#2496980 - 05/16/18 08:30 PM Re: Edelbrock Victor 4500 for RB question [Re: tex013]
tex013 Offline
Ok,
got intake on.
cut 2-3 mm off lower edge and about 4-5mm top . Could maybe go another 1mm lower edge but fits and seals .
Definitely less fuelly at idle without the adapter . Find out this Saturday
rce day
Tex
New best MPH 130.32
#2496994 - 05/16/18 09:10 PM Re: Edelbrock Victor 4500 for RB question [Re: tex013]
Chargerfan68 Offline
Loc: New York, USA
Sorry, did you say this motor and trans is in e-type? That would be one hairy ride, if so
#2496997 - 05/16/18 09:22 PM Re: Edelbrock Victor 4500 for RB question [Re: Chargerfan68]
ozymaxwedge Offline
Loc: Australia
No , you have your wires crossed bud, Tex runs a mechanical business and I guess had some other work to do on a Jag, nothing to do with his all mopar car.
1963 Plymouth Max Wedge
1971 Barracuda
#2497028 - 05/16/18 10:19 PM Re: Edelbrock Victor 4500 for RB question [Re: ozymaxwedge]
tex013 Offline
thank god for that !10 hrs and the jag engine/box is nearly out
Tex
New best MPH 130.32
25,705 Registered Members
196,818 Topics
Can you make a Dominator carb streetable?
by GY3
4 minutes 40 seconds ago
Sputter / backfire FiTech fuel injection
by BDW
16 minutes 3 seconds ago
Worst dragracer ever
by BloFish
18 minutes 44 seconds ago
First 68 Super Bee
by moparpollack
21 minutes 19 seconds ago
