#2496908 - 05/16/18 04:24 PM Quick Fuel Slayer carb leak help
modelmakerinc Offline
Loc: west palm beach, florida
Guys, I recently got my 383 buttoned up and did the run in, all is well except for a fuel sepage at the secondary shafts where the Vacuum lever is.
Once the motor is off I get quite a few drips from the area, is not a "Leak" type drip but seas out enough to be concerning.
It is Quick Fuel Slayer 750. 2 year old shelf life in a box, but was unused until now. Effectively a brand new carb
Edited by modelmakerinc (05/16/18 04:30 PM)
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
#2496918 - 05/16/18 05:07 PM Re: Quick Fuel Slayer carb leak help [Re: modelmakerinc]
Loc: Bend,OR USA
I would check the rear float level to see if it is to high scope twocents
The only reason I can think of that can cause what your seeing is fuel dripping out of the rear venturis boosters onto the shafts shruggy
#2496962 - 05/16/18 07:19 PM Re: Quick Fuel Slayer carb leak help [Re: modelmakerinc]
The fuel level is 1/2 way up the rear sight glass, it is a bit higher than the front though.
#2497065 - 05/17/18 01:18 AM Re: Quick Fuel Slayer carb leak help [Re: modelmakerinc]
Loc: Bend,OR USA
I would lower it to the very bottom of the sight glass and try that scope twocents
#2497182 - 05/17/18 11:31 AM Re: Quick Fuel Slayer carb leak help [Re: Cab_Burge]
dogdays Offline
On Holley type carbs with the level plugs, the fuel is just starting to trickle out over the bottom threads when the level is set properly. I'm not sure how much bigger the sight glasses are than the plug, but halfway up is way high, as suggested above.
When I am doing a quick and dirty fuel bowl R&R I turn the bowl upside down and set the top of the float parallel to the top of the bowl.
R.
#2497237 - 05/17/18 02:00 PM Re: Quick Fuel Slayer carb leak help [Re: modelmakerinc]
lewtot184 Offline
Loc: usa
secondary fuel levels on holley and holley clone carbs should be lower than the primary side. this is by design to prevent fuel sloshing out the boosters during braking. metering plates don't like high fuel levels.
25,705 Registered Members
196,818 Topics
Can you make a Dominator carb streetable?
by GY3
4 minutes 40 seconds ago
Sputter / backfire FiTech fuel injection
by BDW
16 minutes 3 seconds ago
Worst dragracer ever
by BloFish
18 minutes 44 seconds ago
First 68 Super Bee
by moparpollack
21 minutes 19 seconds ago
