kelsey hayes A-body 4-piston calipers are they all the same? #2496852
05/16/18 03:06 PM
05/16/18 03:06 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
Are the calipers all the same? what about the combination valve?
what's the correct master cylinder casting number for a '71 with manual disc brakes?
Re: kelsey hayes A-body 4-piston calipers are they all the same? [Re: 6bblgt] #2496862
05/16/18 04:14 PM
05/16/18 04:14 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Calipers are all the same. 1965-72.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: kelsey hayes A-body 4-piston calipers are they all the same? [Re: 6bblgt] #2496888
05/16/18 05:18 PM
05/16/18 05:18 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
Casting number 2225641
Re: kelsey hayes A-body 4-piston calipers are they all the same? [Re: hemi71x] #2497008
05/16/18 11:40 PM
05/16/18 11:40 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Jim Lusk has stated there are couple of differences with the early ones.
There are two differences, but only one is the caliper itself (the other is the retainer, one large retainer on early models and two smaller ones on later). The major difference is the dust seal and how it attaches. Early calipers have a steel ring that the seal goes around (the seal can be installed after the piston) while the later has another groove cut into the cylinder. This is where rebuild kits are critical. Some kits have four of each style while some only have the early seal. This is all because that seal is the same as the 65-67 Mustang.
Re: kelsey hayes A-body 4-piston calipers are they all the same? [Re: 6bblgt] #2497012
05/16/18 11:52 PM
05/16/18 11:52 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Here's direct to a picture of the combo valve:
page 8, 1970 Master Technicians Conference Brake Hydraulics
1970 can get confusing with all the variations.
The illustration also shows the metering valve, which was not used with the a-body K-H fixed caliper system. On the next page is a chart that indicates which disk brake systems got the metering valve. (The metering valve is to create a slight delay on the front brakes)
1972 illustration is clearer:
http://www.imperialclub.org/Repair/Lit/Master/293/page13.htm
Same combo valve for A-body disks as '71 and '70.
Those booklets explains all of the valves and the 1970 booklet has a list of master cylinders on the back.
P.S. Two good resources for factory info not in your service manual or parts book:
http://www.imperialclub.org/Repair/Lit/Master/index.htm
http://www.hamtramck-historical.com/
(go to the library)
Re: kelsey hayes A-body 4-piston calipers are they all the same? [Re: JRepucci] #2497024
05/17/18 12:15 AM
05/17/18 12:15 AM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
this is not the correct one for 71
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
