Edelbrock Victor 4500 for RB question
#2495660
05/13/18 07:59 PM
05/13/18 07:59 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
Recently bought 1 for my 505 . And started port matching . I have CNC stealths . It would seem these are cast as for max wedge and stock port , just not opened up . 2 questions - looks like I will have to remove across top of ports to fit rocker covers . I have Mopar cast type . - I may have to do the same across bottom of ports as well Is this correct ? I have seen in the TF270 thread , after I started that the port / bolt holes appear to be raised 0.050 in manifold face . I am using the Trickflow valley plate , Andy's batwings and Superformance gaskets thanks ,
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Edelbrock Victor 4500 for RB question
[Re: tex013]
#2495946
05/14/18 01:35 PM
05/14/18 01:35 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
You have all the parts in front of you....... I would think it's pretty obvious what needs to be removed.
I'm not sure how the size and placement of the cnc'd port openings for MW stealths is compared to OE MW heads, but compared to the std ports..... The MW port openings go higher and lower than the std ports.
Edit: after re-reading your post, I guess I'm unclear exactly what you have going on there or what you're trying to do.
You mention the TF270 heads, which are raised runner MW heads..... But then you also talk about the batwings, which are for non-raised runner std port heads.
MP MW gasket on 518 headMP MW gasket on stealth head being opened up to use OE MW intake
[Re: tex013]
#2496142
05/14/18 08:28 PM
05/14/18 08:28 PM
tex013
Sydney,Australia
Thanks Dwayne I have stock port size with the CNC stealth So time to grind more I may have been unclear - I meant across top and bottom on external of gasket , not the actual port opening . Where you can see bearing blue on picture
Tex
[Re: tex013]
#2496388
05/15/18 12:04 PM
05/15/18 12:04 PM
fast68plymouth
So. Burlington, Vt.
I put an Indy 440-2 on some rpm heads years ago. I used an .080" thick piece of aluminum for a valley plate, and had to remove quite a bit off the lower edge of the manifold, and double gasket it, to make it fit. But the heads and intake were MW size.
[Re: tex013]
#2496578
05/15/18 07:39 PM
05/15/18 07:39 PM
tex013
Sydney,Australia
ok thanks yes will hopefully test fit this afternoon 1st though is pull motor/gearbox out of E Type Jag
Tex
[Re: tex013]
#2496980
05/16/18 10:30 PM
05/16/18 10:30 PM
tex013
Sydney,Australia
Ok, got intake on. cut 2-3 mm off lower edge and about 4-5mm top . Could maybe go another 1mm lower edge but fits and seals . Definitely less fuelly at idle without the adapter . Find out this Saturday rce day
Tex
[Re: tex013]
#2496994
05/16/18 11:10 PM
05/16/18 11:10 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Sorry, did you say this motor and trans is in e-type? That would be one hairy ride, if so
[Re: Chargerfan68]
#2496997
05/16/18 11:22 PM
05/16/18 11:22 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Sorry, did you say this motor and trans is in e-type? That would be one hairy ride, if so No , you have your wires crossed bud, Tex runs a mechanical business and I guess had some other work to do on a Jag, nothing to do with his all mopar car.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: ozymaxwedge]
#2497028
05/17/18 12:19 AM
05/17/18 12:19 AM
tex013
Sydney,Australia
Sorry, did you say this motor and trans is in e-type? That would be one hairy ride, if so No , you have your wires crossed bud, Tex runs a mechanical business and I guess had some other work to do on a Jag, nothing to do with his all mopar car. thank god for that !10 hrs and the jag engine/box is nearly out Tex
