Conversion from manual drum to power disc brakes on #249529
03/10/09 01:33 PM
03/10/09 01:33 PM
Minneapolis, MN
W
WHLChallenger Offline OP
W
Minneapolis, MN
Okay guys, so here's the deal. I was able to source a complete power disc brake set up from a '72 Charger about 4 years ago. According to the info I had at the time this is suppose to be a direct bolt in and factory appearing installation. I know that there are better aftermarket systems available but I want my '72 Challenger to appear as factory correct in every way possible. Included in the parts that I received are the original factory power brake booster and proportioning valve. I have two questions . .
1. Should I bother to have the booster restored or are there correct appearing replacements available?
2. Will the proportioning valve also need to be restored or rquired other attendtion or can I expect this thing to work without doing anything to it.
Re: Conversion from manual drum to power disc brakes on [Re: WHLChallenger] #249530
03/10/09 06:17 PM
03/10/09 06:17 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
I would'nt bother restoring the booster, but the prop valve has to be the one that goes with disc...if you had drums....no good !
If in trouble. call MP Brakes...
Dan
Re: Conversion from manual drum to power disc brakes on [Re: Wedgeman] #249531
03/12/09 02:04 PM
03/12/09 02:04 PM
Minneapolis, MN
W
W
Minneapolis, MN
Re: Conversion from manual drum to power disc brakes on [Re: Wedgeman] #249532
03/12/09 02:09 PM
03/12/09 02:09 PM
Minneapolis, MN
W
W
Minneapolis, MN
I have the proportioning valve for the disc set up but it's out of a '72 Charger and going into a '72 Challenger, will this matter? Will the valve need to be rebuilt or serviced? Who ever removed the proportioning valve simply cut the brake lines with a side cutter and threw it in a box along with all the other disc brake parts. I an simply bolt this proportioning valve into my Challenger and expectit to work after all these years of just sitting on a shelf?
Re: Conversion from manual drum to power disc brakes on [Re: WHLChallenger] #249533
03/12/09 06:28 PM
03/12/09 06:28 PM
ne
broncobra Offline
broncobra  Offline
ne
I wouldn't mess with reusing the old corroded crap. Inline Tube has the correct appearing functioning ones you need. I haven't ordered from them yet, but plan too.
Re: Conversion from manual drum to power disc brakes on [Re: WHLChallenger] #249534
03/09/11 11:58 PM
03/09/11 11:58 PM
ny usa
1fastcuda Offline
1fastcuda  Offline
ny usa
hI
i RESTORED A FRONT MANUAL DRUM ON MY 70 E-BODY FROM A 74 E-BODY
i PURCHASED THE BRAKE BOOSTER FROM ADVANCE AUTO PRO VALVE BOUGHT ON
LINE E-BODY i MADE ALL MY LINES WAS NOT RESTORING TO PERFECT
PERFECT COSTS ALOT. pRETTY SIMPLE TO CHANGE OVER i REPLACED ALL MY
FRONT BUSHINGS WHILE APART THATS NOT FUN BUT DID IT WITH HEAT.
i HAD TO GET THE PEDAL ADAPTER FOR BRAKE PEDAL FOR 4 SPEED i CONVERTED TO 4 SPEED FROM AUTO ANY PROBLEMS LET ME KNOW kEVIN
