Re: picked up a 80688 holley 1050 to try
[Re: moparx]
#2500779
05/26/18 08:33 PM
05/26/18 08:33 PM
dartman366
Mt. Vernon, Ohio
nice holder you made for drilling the screws. i forgot to mention that also. a guy can do a lot without needing a mill or lathe, but in my opinion, a drill press is a must. I did the same thing myself and also made a guide to hold the tap's straight while tapping the holes, being a machinist has it's perk's.
[Re: dartman366]
#2500972
05/27/18 12:16 PM
05/27/18 12:16 PM
Posts: 19,239 north of coder
moparx
nice holder you made for drilling the screws. i forgot to mention that also. a guy can do a lot without needing a mill or lathe, but in my opinion, a drill press is a must. I did the same thing myself and also made a guide to hold the tap's straight while tapping the holes, being a machinist has it's perk's. tap guides are a great thing to have also, and are easy to make as well. if you don't have one handy, or the tapped hole is at an angle in the piece, here is a simple way to do this. take a drill that has a shank size that fits your hole to be tapped snugly. put that in the chuck of your press with the flutes in the chuck. [you don't have to tighten the drill as you would when drilling the correct way.] using the backwards drill to position your hole, FIRMLY clamp your work piece to the table of your press so it can't possibly move. clamp your tap in the drill press chuck. lower the quill to your work. then using both hands, turn the chuck with one hand while applying slight, downward pressure to the feed handle with the other. this will allow you to get some starter threads in your work. after a few revolutions, hold the handle firmly in position. DO NOT allow it to move. using your free hand, loosen the chuck with the key, allowing the tap to stay in the work piece, while allowing the quill to be raised. you can now tap the piece by hand. it will be straight because it was lined up by the hole in the piece and the chuck. a machinist does have it's "quirks".
[Re: moparx]
#2501117
05/27/18 10:12 PM
05/27/18 10:12 PM
dartman366
Mt. Vernon, Ohio
nice holder you made for drilling the screws. i forgot to mention that also. a guy can do a lot without needing a mill or lathe, but in my opinion, a drill press is a must. I did the same thing myself and also made a guide to hold the tap's straight while tapping the holes, being a machinist has it's perk's. tap guides are a great thing to have also, and are easy to make as well. if you don't have one handy, or the tapped hole is at an angle in the piece, here is a simple way to do this. take a drill that has a shank size that fits your hole to be tapped snugly. put that in the chuck of your press with the flutes in the chuck. [you don't have to tighten the drill as you would when drilling the correct way.] using the backwards drill to position your hole, FIRMLY clamp your work piece to the table of your press so it can't possibly move. clamp your tap in the drill press chuck. lower the quill to your work. then using both hands, turn the chuck with one hand while applying slight, downward pressure to the feed handle with the other. this will allow you to get some starter threads in your work. after a few revolutions, hold the handle firmly in position. DO NOT allow it to move. using your free hand, loosen the chuck with the key, allowing the tap to stay in the work piece, while allowing the quill to be raised. you can now tap the piece by hand. it will be straight because it was lined up by the hole in the piece and the chuck. a machinist does have it's "quirks". yes, we are a quirky bunch
[Re: Clanton]
#2502263
05/30/18 03:09 PM
05/30/18 03:09 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Driving it or just in neutral?
if when driving.......Put the pv back in and take out a bunch of jet.
Smaller ifr.
Bigger iab.
One thing at a time
[Re: fast68plymouth]
#2502265
05/30/18 03:13 PM
05/30/18 03:13 PM
Posts: 4,488 northern,Ohio,USA
Clanton
northern,Ohio,USA
Smaller ifr.
Bigger iab.
One thing at a time Just in neutral.I will take out a bunch of jet next.The richness is progressive if that helps
[Re: Clanton]
#2502269
05/30/18 03:20 PM
05/30/18 03:20 PM
fast68plymouth
So. Burlington, Vt.
I wouldn't spend much time tuning a drivability issue..... Without actually driving it.
[Re: Clanton]
#2502278
05/30/18 03:28 PM
05/30/18 03:28 PM
Clanton
northern,Ohio,USA
11.9 off idle 12.8 steady state 3k rpm now I think I can drive it and trust it.
[Re: Clanton]
#2502309
05/30/18 04:24 PM
05/30/18 04:24 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
I would shoot for, and do 14.5 AFR or leaner at light part throttle cruise below 2700 RPM in high gear That really helps keep the spark plugs clean Anything richer than 13.8 AFR or lower at part throttle cruise seems to be more responsive but sometimes the butt dyno can be fooled by sensations
[Re: Clanton]
#2502422
05/30/18 09:57 PM
05/30/18 09:57 PM
Clanton
northern,Ohio,USA
Not to get too far ahead of myself but the emulsion jets[3 top,bot,middle]looked small like in the .020 but are not replaceable?Could this be pulling in the extra fuel? ps:When I change the jets in the sec side tomorrow I will check the e jets
[Re: Clanton]
#2502546
05/31/18 03:10 AM
05/31/18 03:10 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
IF they really are .020 I'd plug the middle and drill/ream #1 and 3 to .026 and go from there...........
[Re: Clanton]
#2502578
05/31/18 09:10 AM
05/31/18 09:10 AM
Clanton
northern,Ohio,USA
I will check them with pin drill bits around lunch time.Should I try to get the main jet back to the 84 in this process?Having to drill the metering plate I don't think I can block any very well.
