Help me with the wire pinout 91-96 Dakota multiswitch #2493422
05/07/18 11:36 PM
05/07/18 11:36 PM
Freeport IL USA
poorboy Offline OP
poorboy  Offline OP
Freeport IL USA
Can someone with a 91-96 Dakota service manual give me the wire pin out for the steering column multi switch (turn, 4 way, wiper, ign switch)?
We had a wiring issue with the switch and the plug received fatal damage. I have a replacement switch and a replacement plug, but the wire colors are different. I need to splice the new plug into the existing harness, about 6" behind the plug. I can trace the wires to where they go, but I have no idea where they connect to the switch. Gene
Re: Help me with the wire pinout 91-96 Dakota multiswitch [Re: poorboy] #2493625
05/08/18 01:48 PM
05/08/18 01:48 PM
Eastern Ontario
shaker340 Offline
shaker340  Offline
Eastern Ontario
Poorboy, I have a 96 Dakota manual. I can check for you...I have to do this for my project as well.
Mike
2008 Challenger SRT8
1940 Chrysler Royal coupe
Re: Help me with the wire pinout 91-96 Dakota multiswitch [Re: poorboy] #2493807
05/08/18 11:25 PM
05/08/18 11:25 PM
Freeport IL USA
poorboy Offline OP
poorboy  Offline OP
Freeport IL USA
Mike, Thank You for the pin out. It is exactly what I needed. Now, when I get some time, I will get it back to working again. Gene
