Aftermarket lights wireing? #2492961
05/06/18 10:55 PM
05/06/18 10:55 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
I need to tap into the parking lights wiring on a 95-Ram were's a good place for this? I thought of the fuse box but this carry's 12 volt constantly at the fuse work ........Thaxs
Re: Aftermarket lights wireing? [Re: racerx] #2493039
05/07/18 01:35 AM
05/07/18 01:35 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
what are you installing as far as draw of the system. Tapping into the wiring at one of the lights and adding a relay should work.
Re: Aftermarket lights wireing? [Re: stumpy] #2493086
05/07/18 07:34 AM
05/07/18 07:34 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
it's just a set of aftermarket road lights that I had maybe 20 years or so, the instruction say to run one wire to the park lights. Wondering if there's a wiring connector available for tapping into the harness for this .......Thaxs for the response. up
Never mind on the wire taps found it down have to think of something else as for as tapping into the lighting system.
