Re: Tach goes crazy and engine starts missing
[Re: dirt]
#2491411
05/03/18 12:24 PM
05/03/18 12:24 PM
Posts: 11,525 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Sounds like pick up, although they usually either work or they don't. Swap in a known good box would be the second choice. Look at the wiring for damage or shorts.
[Re: dirt]
#2491516
05/03/18 03:03 PM
05/03/18 03:03 PM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
Hopefully you aren't still running the factory ammeter/ampmeter in the car? If so, it could be going bad b/c when mine went, that's how it started...right before it burned up the wiring harness.
Also seen a bad tach cause weird misfiring issues. Unplug it and try.
[Re: MR_P_BODY]
#2491559
05/03/18 04:16 PM
05/03/18 04:16 PM
Posts: 4,711 Moved to N.E. Tennessee
GomangoCuda
When this happened to me my first thought was bad tach. Disconnected it at the coil and the ignition was back to normal. I was ready to pull the trigger on a new tach when it occurred to me that there was also a rev limiter connected to the same wire. Unhooked it and hooked The tach back up. Yeah it was the rev limiter.
[Re: dirt]
#2491822
05/04/18 07:25 AM
05/04/18 07:25 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Just posted this a few days ago on this thread https://board.moparts.org/ubbthreads/ubbt...tml#Post2233534Sounds like a lot of MSD Coils are failing lately from the research I did the last few days Had my new 432 Stroker on the road the other day for the first time in over a year Cruising on the highway after about a hour the engine started missing at high rpms Turned around and headed home , where it started getting worse even at lower cruise What I first noticed was the tachometer needle was bouncing all over the place , had a mind of its own Went to touch the MSD 8202 Red Coil checking the tach wire , was super super hot Just swapped in a old Mopar Resto coil that I had laying around along with a .8 resistor Ran it for a few hours problem solved This MSD 8202 Coil I had for about 5 years , ran fine with MP Chrome ECU , MP Distributor prior First day with the new motor , had me wondering now what - The Tach issue was the only thing that pointed me directly to the coil Anyways , this MSD 8222 Epoxy Coil - Better ? Same ? Is there a better coil in factory location bracket on aluminum intake ? Or is it time for a FBO Upgrade or Rev n nator Upgrade for this new motor Street Use Thanx Scott
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: dirt]
#2492036
05/04/18 03:34 PM
05/04/18 03:34 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I can see an internal short or failure causing that, if the tach signal is being picked up right at the coil primary terminal and not the port at an MSD box.
[Re: dirt]
#2492263
05/05/18 01:20 AM
05/05/18 01:20 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
This is what I had happen back in the 80's with my Fiero GT. same symptoms . 1 spark plug wire had a crack and for some reason every once and awhile it would start throwing sparks to the block making a miss and screwing up the tach. Took a while to figure it out but a change of wires did the trick.
[Re: dirt]
#2493027
05/07/18 01:17 AM
05/07/18 01:17 AM
Posts: 52,972 Romeo MI
MR_P_BODY
10 years is a long time for plug wires.. since it was raining out I would look under the hood in the dark and see if the spark is jumping under there.. but I would start with wires
[Re: dirt]
#2493193
05/07/18 02:14 PM
05/07/18 02:14 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Use a spray bottle with water in it and spray a fine mist on the wires after dark. You'll find out pretty quick what condition the wire insulation is in.
