Page 5 of 5 1 2 3 4 5
Re: Who has used the new MM block? [Re: tex013] #2494186
05/10/18 12:06 AM
05/10/18 12:06 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Originally Posted By tex013
Originally Posted By Old School
Damn, that looks heavy!!
but if it holds together are you going to complain ?
As an aside , are the aluminium ( Indy , World ? ) good enough for daily driving or more a race only item ?
Tex
My Indy aluminum block is in a 100% street car, makes 960 hp. No problems yet.....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Who has used the new MM block? [Re: turbo toad] #2494195
05/10/18 12:26 AM
05/10/18 12:26 AM
NW Pa.
KD800X Offline
KD800X  Offline
NW Pa.
Originally Posted By turbo toad
Originally Posted By KD800X
I'll ask the question again.
Does the new Iron blocks even exist?
Yes they do i spoke with the supplier on sunday and he told me theres about a 5 week lead time as of right now
I mentioned a guy with his block at Best Machine they were going over it to see if there was any issue only thing they said was oil pump bolt holes are alittle off and oil pump mounting holes will need to be opened up to line it up and the lifter bores had a taper
I attached a pic of his block which he picked up from Best of the weekend.
Thank you sir, that's a beautiful sight!
Is this block going to be a Mopar block or is this strictly an outside source?
Re: Who has used the new MM block? [Re: Old School] #2494215
05/10/18 01:14 AM
05/10/18 01:14 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Tex
thanks
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Who has used the new MM block? [Re: Hot 340] #2498112
05/20/18 03:04 AM
05/20/18 03:04 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
"We are currently in the middle of some foundry updates and at the same time decided to use the down time to upgrade the tooling to improve the casting quality. Projected ship dates to begin in late Summer 2018."
https://www.billmitchellproducts.com/mopar-aluminum-big-block/
Floyd Lippencott IV
