Gear vendors electronic speed sensor #2488572
04/27/18 06:05 AM
04/27/18 06:05 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
I recently bought a used Gear Vendors overdrive but it didn't come with the electronic speed sensor and the short speedo cable extension.
Searching for a speed sensor I came across an electronic one made by Dakota Digital which looks remarkably close to the GV sensor. Even the cable colors (black and white) are the same. I wouldn't be surprised if GV indeed uses the Dakota unit. What do you think?
Gear Vendors sensor:
Dakota Digital unit:
Furthermore I found a 20" speedo cable with 5/8" and 7/8" ends made by Pioneer which should work. Can anyone confirm that the GV speedometer cable ends are 5/8" and 7/8"?
Re: Gear vendors electronic speed sensor [Re: DGS] #2491296
05/03/18 04:49 AM
05/03/18 04:49 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
No Gear Vendors users here?
Re: Gear vendors electronic speed sensor [Re: DGS] #2491777
05/04/18 12:16 AM
05/04/18 12:16 AM
IL
BlwnCrcab Offline
BlwnCrcab  Offline
IL
looks just like the one that came w my kit
