Anyone using the Trans-Dapt /6 to smallblock v8 swap mounts #2488556
04/27/18 02:22 AM
04/27/18 02:22 AM
Ohio
moparjoe360.4 Offline OP
Ohio
I tried this in the Q&A board with no response so I figured I’d check here.
I was looking at different options for putting my 410 stroker into my recently aquired 71 Duster and ran across the Trans-Dapt Performance Engine Swap Motor Mounts 4695, they’re 1/2 the price of the Schumacher a67a6 A body V8 conversion mounts. Cheaper isn’t always better though so I figured is see if anyone here had run them. I also plan on putting headers on it so those have to clear everything too. I might also just swap to a V8 K member. Any help would be appreciated.
Here’s a link to the mounts on Summit.
https://www.summitracing.com/parts/trd-4695
Re: Anyone using the Trans-Dapt /6 to smallblock v8 swap mounts [Re: moparjoe360.4] #2488593
04/27/18 09:18 AM
04/27/18 09:18 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Used them to put a 360 in my 69 barracuda that is a factory /6 car. Worked great. Everything fit as it should. I used summit brand headers.
Re: Anyone using the Trans-Dapt /6 to smallblock v8 swap mounts [Re: moparjoe360.4] #2488703
04/27/18 02:59 PM
04/27/18 02:59 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
I used them putting my 408 in a '69 Valiant, used a set of no-name headers, had to do some massaging with a ballpeen, but the mounts seemed to fit pretty well.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Anyone using the Trans-Dapt /6 to smallblock v8 swap mounts [Re: johnnycuda] #2488776
04/27/18 07:17 PM
04/27/18 07:17 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Joe, if you need more feedback I'd try Forabodiesonly.com. lots of info there.
Gary
Re: Anyone using the Trans-Dapt /6 to smallblock v8 swap mounts [Re: moparjoe360.4] #2488792
04/27/18 07:42 PM
04/27/18 07:42 PM
Ohio
Ohio
Thanks for the info guys! I’ll probably give them a try.
Gary that’s a great idea, now that I’m an A body owner I should probably join that board too! Hope your winter was good, did you get your hood replaced? I’m still trying to get my engine back together but it’s close. Hopefully I can have it in the truck n make it up to Milan for Detroit Dragway reunion.
Re: Anyone using the Trans-Dapt /6 to smallblock v8 swap mounts [Re: moparjoe360.4] #2488875
04/27/18 11:29 PM
04/27/18 11:29 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
i Ended up putting the steel hood on.
I still have the pieces.. hanging up in the barn. Been a busy winter, picked up a '64 more door Dart to put my old 340 in, then last month we picked up a '79 Ramcharger, so now have 2 hot rods and a 4 wheeler and none are quite ready, Challenger need either a wheel bearing or pinion bearings, not sure yet, and the RC needs headers and Tires, so hopefully I'll have something ready for DD also.
Re: Anyone using the Trans-Dapt /6 to smallblock v8 swap mounts [Re: moparjoe360.4] #2488897
04/28/18 12:10 AM
04/28/18 12:10 AM
Ohio
Ohio
That’s awesome, new toys are always fun! The Challenger looks good with the steel hood, at least you had a spare to use! Here’s a few pictures of my Duster.
F8973019-470B-491C-9108-5DA8A974BA8B.jpegBCF89B9F-FAC1-41D0-8B80-74EE177435BE.jpegA15BC796-E927-419B-82C1-6FF252D37290.jpeg
Re: Anyone using the Trans-Dapt /6 to smallblock v8 swap mounts [Re: moparjoe360.4] #2489061
04/28/18 02:03 PM
04/28/18 02:03 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
The Duster looks good, Should be a fun project. I think I'd paint it Flat black to match your truck, it looks like it's half way there. some wheels and tires, a drivetrain and you're all set up
Re: Anyone using the Trans-Dapt /6 to smallblock v8 swap mounts [Re: moparjoe360.4] #2489454
04/29/18 12:20 PM
04/29/18 12:20 PM
Ohio
Ohio
Flat black with blue stripes was my initial plan, but we’re already kicking around he idea of gloss black with blue stripes or darker blue possibly (B7). Right now it’s a blank canvas to start from. I’ve just got to try to match the brown interior that I’m planning to keep because most of it is in good shape.
