Re: 1972 Roadrunner Speedometer Bounce
[Re: jim6346]
#2488222
04/26/18 01:02 PM
04/26/18 01:02 PM
RapidRobert
pull the inner cable out of the sheath up at the speedo end & lube it with some graphite lube from your parts house. dont get the lube real close to the speedo head, maybe up to the "collar"
[Re: RapidRobert]
#2488256
04/26/18 01:56 PM
04/26/18 01:56 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
pull the inner cable out of the sheath up at the speedo end & lube it with some graphite lube from your parts house. dont get the lube real close to the speedo head, maybe up to the "collar" Yes... There is a graphite 'chain&sprocket' lube that works well if used sparingly...
[Re: jim6346]
#2488660
04/27/18 12:34 PM
04/27/18 12:34 PM
RapidRobert
You dont feel lucky! You might unhook the cable at the trans end & straighten it out & spin it with a drill & you may even need to take the speedo head out & spin it up with the inner cable (a short piece of one from a junk cable assy is even easier) to see if the issue is in the head (grab some helpers if using the long OE inner cable).
[Re: jim6346]
#2488863
04/27/18 11:06 PM
04/27/18 11:06 PM
RapidRobert
You might even call a speedometer specialty shop run the symptom by em & see if they think it might be in the head or in the inner cable/sheath. If you do spin the cable use your reverseable drill & go CCW. I dont have the last word but it sounds more like a cable/sheath issue.
[Re: jim6346]
#2499908
05/24/18 11:19 AM
05/24/18 11:19 AM
Posts: 559 Newark Valley, NY
jim6346
Newark Valley, NY
Hi Everyone, Just to close this out, I replaced the speedometer cable and it is now solid as a rock all the way to 100 Thanks everyone for you input! Jim
