Is it possible to drill and tap treads into a stock over running clutch to make it
"bolt on" ?
What are the other considerations I'm over looking or just plain ignorant of ?
thanks.
Is the outer race loose in the case?
Yes is it possible to drill the outer race , that is all the standard replacement bolt in is, a drilled stock unit , it is made to replace 0one that has become loose in the case , it does nothing to stop the over running clutch from failing, if that is your reason for going to a bolt in.
