Thermostat Housing/Cover, Water Neck - Gen 3 Hemi #2487657
04/25/18 06:31 AM
04/25/18 06:31 AM
cbusters Offline OP
cbusters  Offline OP
Are there any options for an angled Thermostat Cover/Water Neck that will fit the 2006 5.7? I am running into a problem getting an upper radiator hose that will fit. Kind of on a deadline. The straight one I have is not working.
Re: Thermostat Housing/Cover, Water Neck - Gen 3 Hemi [Re: cbusters] #2487669
04/25/18 09:04 AM
04/25/18 09:04 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
what car application?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Thermostat Housing/Cover, Water Neck - Gen 3 Hemi [Re: cbusters] #2487685
04/25/18 10:13 AM
04/25/18 10:13 AM
cbusters Offline OP
cbusters  Offline OP
69 b-body.
Re: Thermostat Housing/Cover, Water Neck - Gen 3 Hemi [Re: cbusters] #2487731
04/25/18 12:05 PM
04/25/18 12:05 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I've only noticed straight ones from the factory. So I made my own, cut and added a bend and welded back up... kept the lip on the end also so the hose stays on.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Thermostat Housing/Cover, Water Neck - Gen 3 Hemi [Re: Silver70] #2487867
04/25/18 05:28 PM
04/25/18 05:28 PM
cbusters Offline OP
cbusters  Offline OP
That is what I was seeing as a last resort. I was going to start looking for a real tight bent 1-3/4" 90 degree tube. Maybe another water outlet application that I can cut off.
Re: Thermostat Housing/Cover, Water Neck - Gen 3 Hemi [Re: cbusters] #2488119
04/26/18 08:48 AM
04/26/18 08:48 AM
cbusters Offline OP
cbusters  Offline OP
I'm waiting for Goody's response. He's got some options according to application.
Re: Thermostat Housing/Cover, Water Neck - Gen 3 Hemi [Re: cbusters] #2488443
04/26/18 08:46 PM
04/26/18 08:46 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I wouldn't expect that application to be all that far from my ebody. I took a stock one and welded an exhaust adapter to it to neck it down. I have a factory 318 ebody radiator hose on mine.
There's no lip on mine, hose stays on just fine. 2,800 miles thus far.
2020 RAM 1500
Re: Thermostat Housing/Cover, Water Neck - Gen 3 Hemi [Re: cbusters] #2489215
04/28/18 08:46 PM
04/28/18 08:46 PM
Canada
onig Offline
onig  Offline
Canada
That's a good idea.
69 Dart
Re: Thermostat Housing/Cover, Water Neck - Gen 3 Hemi [Re: cbusters] #2496884
05/16/18 05:12 PM
05/16/18 05:12 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I'm running a stock housing with a gates green stripe flex hose. It works fine.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
