Denso 1 wire? #2487437
04/24/18 07:35 PM
04/24/18 07:35 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Anybody have a part number for a small Denso alternator that is 1 wire hook up?
60,80,120 amp
Off of rock auto or eBay
Re: Denso 1 wire? [Re: RV2] #2487442
04/24/18 07:52 PM
04/24/18 07:52 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
you might mean the one with 3 wire plug.
i usually look for an application like a mid 80's toyota truck so it has a v-groove belt.
the hookup is switched 12v source, a 12v reference wire. both of those are in the plug on the alternator.
a stud for the alt output that goes to your battery post or something like that...
the ARengineering website has a pdf of the instructions, mancini sells his kits...
Re: Denso 1 wire? [Re: RV2] #2487535
04/24/18 10:31 PM
04/24/18 10:31 PM
AndyF Offline
AndyF  Offline
I don't know of a Denso alternator that is one wire. You can buy Powermaster one wire alternators. The Powermaster alternators are converted Denso alternators. Denso is an OEM supplier and I don't think any of the OEMs would use a one wire alternator.
Re: Denso 1 wire? [Re: RV2] #2487598
04/25/18 12:44 AM
04/25/18 12:44 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have a Power Master / Denso that has the main stud and the 3 wire plug. I haven't used it yet but was told don't worry about the plug in, just hook up the main stud and run it to the battery. Is that correct?
Re: Denso 1 wire? [Re: RV2] #2487599
04/25/18 12:47 AM
04/25/18 12:47 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
flaming river makes a one wire denso alternator but its ridiculously priced. only one I've seen
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Denso 1 wire? [Re: rowin4] #2487600
04/25/18 12:52 AM
04/25/18 12:52 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
It wont work like that you need to have it wired with the plug for the internal regulator to operate. You need to get the plug from Andy and wire it up as the diagram shows.
The Toyota Denso alternator works fantastic when wired correctly and will outlast any other alternator and you don't need an external regulator.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Denso 1 wire? [Re: RV2] #2487664
04/25/18 08:12 AM
04/25/18 08:12 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Throw this number into the google machine.
126000-0550
You can turn an externally regulated ND alternator into a 1 wire. This number doesn’t work for every ND alternator, but you can get a one wire regulator for any ND alternator if you search a little bit.
I still recommend using an external regulator over the one wire stuff... Just my preference.
Re: Denso 1 wire? [Re: rowin4] #2487671
04/25/18 09:20 AM
04/25/18 09:20 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'd call powermaster and ask them. Their customer service is very good from my experience.
Re: Denso 1 wire? [Re: RV2] #2487686
04/25/18 10:18 AM
04/25/18 10:18 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I run one of these, works with factory alternator brackets, just have to make the adjusting bracket into more of a U shape. It only requires the 1 main wire and a ground wire.
https://www.jegs.com/i/JEGS-Performance-Products/555/10160/10002/-1
Re: Denso 1 wire? [Re: TRENDZ] #2487690
04/25/18 10:22 AM
04/25/18 10:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
126000-0550
I use the external regulators all the time.. why
throw a alt out if its just a cheap reg and most
times it is the reg
wave
Re: Denso 1 wire? [Re: fourgearsavoy] #2487725
04/25/18 12:00 PM
04/25/18 12:00 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Gus beer
was my experience as well, i had the 12v reference wire and the keyed 12v switched on my plug and the alt didn't work. swapped the wires and it works great.
13.5v at idle. i kinda want to put one on my beater truck too so the lights don't flicker so much at lights...
Re: Denso 1 wire? [Re: MR_P_BODY] #2487910
04/25/18 07:17 PM
04/25/18 07:17 PM
Rittman Ohio
Rittman Ohio
126000-0550
times it is the reg
wave
Because it's NEVER the regulator on a Toyota alternator,they usually wear out the brushes in about 120,000 miles then all you need to do is install a new brush holder for about $15.00
Gus beer
64 Plymouth Savoy
Dana 60
Re: Denso 1 wire? [Re: RV2] #2488064
04/26/18 01:33 AM
04/26/18 01:33 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
93 Geo Metro!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Denso 1 wire? [Re: RV2] #2488168
04/26/18 11:12 AM
04/26/18 11:12 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Look at your local starter alternator rebuild shop. They should have converted Denso's for way less that a Powermaster.
