New Yorker diff fluid #2487450
04/24/18 08:04 PM
04/24/18 08:04 PM
Rust Land--CNY
TheCrystalShip Offline OP
Rust Land--CNY
What type of axle fluid should I use for a '66 New Yorker with an 8 3/4 Sure-Grip?
Re: New Yorker diff fluid [Re: TheCrystalShip] #2487500
04/24/18 09:28 PM
04/24/18 09:28 PM
IN
ahy Offline
ahy  Offline
IN
Standard 80W90 with limited slip additive should be fine. I generally use the limited slip additive from Autozone which is (I think) GM spec. It works fine.
Try to run without the additive and you will get chatter and chirping on turns.
