Re: Denso 1 wire?
[Re: RV2]
#2487598
04/25/18 12:44 AM
04/25/18 12:44 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have a Power Master / Denso that has the main stud and the 3 wire plug. I haven't used it yet but was told don't worry about the plug in, just hook up the main stud and run it to the battery. Is that correct?
Re: Denso 1 wire?
[Re: rowin4]
#2487600
04/25/18 12:52 AM
04/25/18 12:52 AM
Posts: 10,549 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have a Power Master / Denso that has the main stud and the 3 wire plug. I haven't used it yet but was told don't worry about the plug in, just hook up the main stud and run it to the battery. Is that correct? It wont work like that you need to have it wired with the plug for the internal regulator to operate. You need to get the plug from Andy and wire it up as the diagram shows. The Toyota Denso alternator works fantastic when wired correctly and will outlast any other alternator and you don't need an external regulator. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Denso 1 wire?
[Re: RV2]
#2487664
04/25/18 08:12 AM
04/25/18 08:12 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Throw this number into the google machine. 126000-0550 You can turn an externally regulated ND alternator into a 1 wire. This number doesn’t work for every ND alternator, but you can get a one wire regulator for any ND alternator if you search a little bit. I still recommend using an external regulator over the one wire stuff... Just my preference.
Re: Denso 1 wire?
[Re: rowin4]
#2487671
04/25/18 09:20 AM
04/25/18 09:20 AM
Posts: 11,678 W. Kentucky
justinp61
W. Kentucky
I have a Power Master / Denso that has the main stud and the 3 wire plug. I haven't used it yet but was told don't worry about the plug in, just hook up the main stud and run it to the battery. Is that correct? I'd call powermaster and ask them. Their customer service is very good from my experience.
Re: Denso 1 wire?
[Re: TRENDZ]
#2487690
04/25/18 10:22 AM
04/25/18 10:22 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Throw this number into the google machine. 126000-0550 You can turn an externally regulated ND alternator into a 1 wire. This number doesn’t work for every ND alternator, but you can get a one wire regulator for any ND alternator if you search a little bit. I still recommend using an external regulator over the one wire stuff... Just my preference. I use the external regulators all the time.. why throw a alt out if its just a cheap reg and most times it is the reg
Re: Denso 1 wire?
[Re: fourgearsavoy]
#2487725
04/25/18 12:00 PM
04/25/18 12:00 PM
Posts: 2,094 central texas
krautrock
central texas
I have a Power Master / Denso that has the main stud and the 3 wire plug. I haven't used it yet but was told don't worry about the plug in, just hook up the main stud and run it to the battery. Is that correct? It wont work like that you need to have it wired with the plug for the internal regulator to operate. You need to get the plug from Andy and wire it up as the diagram shows. The Toyota Denso alternator works fantastic when wired correctly and will outlast any other alternator and you don't need an external regulator. Gus was my experience as well, i had the 12v reference wire and the keyed 12v switched on my plug and the alt didn't work. swapped the wires and it works great. 13.5v at idle. i kinda want to put one on my beater truck too so the lights don't flicker so much at lights...
Re: Denso 1 wire?
[Re: MR_P_BODY]
#2487910
04/25/18 07:17 PM
04/25/18 07:17 PM
fourgearsavoy
Rittman Ohio
Throw this number into the google machine. 126000-0550 You can turn an externally regulated ND alternator into a 1 wire. This number doesn’t work for every ND alternator, but you can get a one wire regulator for any ND alternator if you search a little bit. I still recommend using an external regulator over the one wire stuff... Just my preference. I use the external regulators all the time.. why throw a alt out if its just a cheap reg and most times it is the reg Because it's NEVER the regulator on a Toyota alternator,they usually wear out the brushes in about 120,000 miles then all you need to do is install a new brush holder for about $15.00 Gus
