#2487437 - 04/24/18 05:35 PM Denso 1 wire?
RV2 Offline
Loc: Covington Georgia
Anybody have a part number for a small Denso alternator that is 1 wire hook up?
60,80,120 amp
Off of rock auto or eBay
#2487442 - 04/24/18 05:52 PM Re: Denso 1 wire? [Re: RV2]
krautrock Online   content
Loc: central texas
you might mean the one with 3 wire plug.
i usually look for an application like a mid 80's toyota truck so it has a v-groove belt.
the hookup is switched 12v source, a 12v reference wire. both of those are in the plug on the alternator.
a stud for the alt output that goes to your battery post or something like that...
the ARengineering website has a pdf of the instructions, mancini sells his kits...
#2487535 - 04/24/18 08:31 PM Re: Denso 1 wire? [Re: RV2]
AndyF Offline
Loc: Oregon
I don't know of a Denso alternator that is one wire. You can buy Powermaster one wire alternators. The Powermaster alternators are converted Denso alternators. Denso is an OEM supplier and I don't think any of the OEMs would use a one wire alternator.
#2487598 - 04/24/18 10:44 PM Re: Denso 1 wire? [Re: RV2]
rowin4 Offline
Loc: gulfport, ms, west mi
I have a Power Master / Denso that has the main stud and the 3 wire plug. I haven't used it yet but was told don't worry about the plug in, just hook up the main stud and run it to the battery. Is that correct?
#2487599 - 04/24/18 10:47 PM Re: Denso 1 wire? [Re: RV2]
Jerry Offline
Loc: Warren, MI
flaming river makes a one wire denso alternator but its ridiculously priced. only one I've seen
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
#2487600 - 04/24/18 10:52 PM Re: Denso 1 wire? [Re: rowin4]
fourgearsavoy Online   tonguue
Loc: Rittman Ohio
It wont work like that you need to have it wired with the plug for the internal regulator to operate. You need to get the plug from Andy and wire it up as the diagram shows.
The Toyota Denso alternator works fantastic when wired correctly and will outlast any other alternator and you don't need an external regulator.
Gus beer
64 Plymouth Savoy
Dana 60
#2487664 - 04/25/18 06:12 AM Re: Denso 1 wire? [Re: RV2]
TRENDZ Offline
Loc: Milwaukee WI
Throw this number into the google machine.
126000-0550
You can turn an externally regulated ND alternator into a 1 wire. This number doesn’t work for every ND alternator, but you can get a one wire regulator for any ND alternator if you search a little bit.
I still recommend using an external regulator over the one wire stuff... Just my preference.
#2487671 - 04/25/18 07:20 AM Re: Denso 1 wire? [Re: rowin4]
justinp61 Offline
Loc: W. Kentucky
I'd call powermaster and ask them. Their customer service is very good from my experience.
#2487686 - 04/25/18 08:18 AM Re: Denso 1 wire? [Re: RV2]
DusterKid Offline
Loc: Keymar, MD
I run one of these, works with factory alternator brackets, just have to make the adjusting bracket into more of a U shape. It only requires the 1 main wire and a ground wire.
https://www.jegs.com/i/JEGS-Performance-Products/555/10160/10002/-1
#2487690 - 04/25/18 08:22 AM Re: Denso 1 wire? [Re: TRENDZ]
MR_P_BODY Offline
Loc: Romeo MI
126000-0550
I use the external regulators all the time.. why
throw a alt out if its just a cheap reg and most
times it is the reg
wave
W-9 8.94 @ 151 NOW ON E-85
Mike "Raff"...(180)Watching over us
CAR IS FOR SALE
#2487725 - 04/25/18 10:00 AM Re: Denso 1 wire? [Re: fourgearsavoy]
Loc: central texas
Gus beer
was my experience as well, i had the 12v reference wire and the keyed 12v switched on my plug and the alt didn't work. swapped the wires and it works great.
13.5v at idle. i kinda want to put one on my beater truck too so the lights don't flicker so much at lights...
#2487910 - 04/25/18 05:17 PM Re: Denso 1 wire? [Re: MR_P_BODY]
Loc: Rittman Ohio
126000-0550
times it is the reg
wave
Because it's NEVER the regulator on a Toyota alternator,they usually wear out the brushes in about 120,000 miles then all you need to do is install a new brush holder for about $15.00
Gus beer
64 Plymouth Savoy
Dana 60
#2488064 - 04/25/18 11:33 PM Re: Denso 1 wire? [Re: RV2]
astjp2 Online   content
Loc: Utah and Alaska
93 Geo Metro!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
#2488168 - 04/26/18 09:12 AM Re: Denso 1 wire? [Re: RV2]
mopar dave Offline
Loc: flint michigan
Look at your local starter alternator rebuild shop. They should have converted Denso's for way less that a Powermaster.
25,705 Registered Members
196,818 Topics
Can you make a Dominator carb streetable?
by GY3
4 minutes 40 seconds ago
Sputter / backfire FiTech fuel injection
by BDW
16 minutes 3 seconds ago
Worst dragracer ever
by BloFish
18 minutes 44 seconds ago
First 68 Super Bee
by moparpollack
21 minutes 19 seconds ago
