Re: Wiring key ignition w/o a ballast resistor
[Re: krautrock]
#2487566
04/24/18 11:18 PM
04/24/18 11:18 PM
RapidRobert
^^^ agreed, confirm the MSD/coil are both being fed in ign1 blue wire (run) & ign2 brown wire (crank)
[Re: krautrock]
#2487665
04/25/18 08:20 AM
04/25/18 08:20 AM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
one wire is hot in "on", one wire is hot in "start". they have to both go to your msd box. I think this is the problem, which wire from the MSD box gets these wires? I think something got cut. Would these wires come off of a relay? I see a bunch of relays on a panel but when I wired up my fuel pump, water pump, and fan I didn't use these relays.I think I have 3 relays back up under the dash
[Re: Sammy]
#2487729
04/25/18 12:03 PM
04/25/18 12:03 PM
Posts: 2,094 central texas
krautrock
central texas
one wire is hot in "on", one wire is hot in "start". they have to both go to your msd box. I think this is the problem, which wire from the MSD box gets these wires? I think something got cut. Would these wires come off of a relay? I see a bunch of relays on a panel but when I wired up my fuel pump, water pump, and fan I didn't use these relays.I think I have 3 relays back up under the dash it will be easiest to find the wires that went to your ballast resistor. blue and brown. they come out of the bulkhead connector on the engine side. those wires tied together and connected to the keyed 12v wire on the msd should work.
[Re: krautrock]
#2487744
04/25/18 12:41 PM
04/25/18 12:41 PM
Sammy
Wind Gap,Pa.
[quote=Sammy][quote=krautrock] it will be easiest to find the wires that went to your ballast resistor. blue and brown. they come out of the bulkhead connector on the engine side.
Thanks I will report back to you. This is a great help.
[Re: Sammy]
#2487787
04/25/18 02:10 PM
04/25/18 02:10 PM
Posts: 19,307 north of coder
moparx
sammy, how many wires do you have coming from your switch ? you should have at least five. 1-12v to switch [usually red] 2-ign. #1 [usually blue-run] 3-ign, #2 [usually brown-12v to coil in start] 4-accessory [usually black] 5-start [usually yellow-to starter relay] hope this helps.
[Re: moparx]
#2487810
04/25/18 03:13 PM
04/25/18 03:13 PM
Sammy
Wind Gap,Pa.
sammy, how many wires do you have coming from your switch ? you should have at least five. 1-12v to switch [usually red] 2-ign. #1 [usually blue-run] 3-ign, #2 [usually brown-12v to coil in start] 4-accessory [usually black] 5-start [usually yellow-to starter relay] hope this helps. This is correct. Yes Black wire to accessory was cut a long time ago. Yellow has no power in the on position.
[Re: krautrock]
#2488414
04/26/18 07:24 PM
04/26/18 07:24 PM
Sammy
Wind Gap,Pa.
[quote=Sammy][quote=krautrock]one wire is hot in "on", one wire is hot in "start". they have to both go to your msd box. [/quote
1st I want to thank you for all your replys and help! I traced the two wires Blue and brown from the engine bay bulkhead and it was spliced into one with a red wire that went through the firewall into the cockpit under the dash and low and behold the wire was cut and it went to the 12v switched wire on the MSD box. The car fired right up without a glitch. You guys are the best and I'm very appreciative for all the help I get on this board.
[Re: Sammy]
#2536682
08/15/18 12:07 PM
08/15/18 12:07 PM
Posts: 5,100 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I'm actually going through this very issue with the 72 Duster now. I installed the MSD system (all plug and play) MSD Box...coil and distributor. I wired everything up temporary to do the break in and everything worked with no issues. I had to rebuild a steering column and convert from Power to manual so I bypassed everything to break the motor in. NOW when I'm wiring everything up complete I have the yellow (Start wire to starter relay) wired up with no issues. The large Red hot for the MSD to a battery hot... Black to ground... Msd run hot wire (Red) tied into the Blue (ignition 1) Here is where I'm wondering why I wouldn't tie the brown wire into the yellow wire and pic up ignition 2 when the switch is in the start position? Is there a downside to having the brown wire tied into the blue (ignition 1) all of the time? Why couldn't it also be tied into the yellow where it only receives juice when the ignition is in the start position? Just an FYI the Solenoid is a Ford unit and is behind the dash along with the MSD box. The only wires I use through the factory pin connectors are the (purple) engine temp wire and the Black Alternator wire. The alternator is a one wire unit so all other wires are terminated at the pin connector.
...FAFO...
[Re: moparx]
#2536712
08/15/18 01:04 PM
08/15/18 01:04 PM
skicker
"The Champ"
"The Champ"
Western Md.
Everything original under the hood was bypassed. The brown...blue and all wiring to and from the ballast resistor and the voltage regulator. All wires were terminated at the Firewall plug. The coil is being powered directly by the MSD Box. The constant 12 volts would be supplied from the blue wire (Ignition 1)that is tied into the MSD (Small Red)... I can tie the brown in with the blue but I wasn't sure if it would hurt anything. By tying it into the yellow I knew it would only have 12 volts while cranking...(ignition 2) In reviewing a few diagrams I think it would work either way??? The Ford starter relay has two connections but allows for 1 large wire to run to the starter while having both terminals on the starter crossed with a metal plate. This wire is only hot once energized by the yellow wire attached to the relay.
...FAFO...
[Re: krautrock]
#2536779
08/15/18 03:11 PM
08/15/18 03:11 PM
dogdays
Exactly correct.
You could also put a hidden switch in the brown wire as sort of an antitheft device.
For someone who asked whether the MSD coil was hooked up to power, the coil is only hooked up to the MSD box. That is where the coil gets its energy, from the capacitor in the MSD box. The coil needs to be grounded, in order to have a complete circuit from coil thru distributor rotor, plug wires, plug, across the gap, into ground, back to coil..
R.
[Re: Sammy]
#2536865
08/15/18 07:31 PM
08/15/18 07:31 PM
Posts: 314 Medina, OH
dart440_72
Medina, OH
I ended up connecting the blue and brown wires to a bus bar. I connected all of my 12v switched items to the bar as well. Works great!
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
