Cylinder head tool recommendation please #2486200
04/21/18 10:15 PM
04/21/18 10:15 PM
Granbury TX
Prochargedmopar Offline OP
Granbury TX
For a stock late 90’s sb Magnum head.
Does anyone know off hand which tool I buy to cut the valve guides down to increase retainer to guide clearance?
Got a link?
I think it resizes for pc seals also.
thanks
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: Cylinder head tool recommendation please [Re: Prochargedmopar] #2486247
04/22/18 12:16 AM
04/22/18 12:16 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Summit would have it. I bought tools to open valve pockets there. Best to call their tech line if you aren’t sure
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cylinder head tool recommendation please [Re: Prochargedmopar] #2486265
04/22/18 01:31 AM
04/22/18 01:31 AM
P
Porter67 Offline
Porter67  Offline
P
Ask Cab_Burge on here, im pretty sure at one time he posted the site where he gets his and although I forget its the same one I have, its about 85$.
Re: Cylinder head tool recommendation please [Re: Prochargedmopar] #2486298
04/22/18 03:14 AM
04/22/18 03:14 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Cylinder head tool recommendation please [Re: John_Kunkel] #2486713
04/23/18 05:18 AM
04/23/18 05:18 AM
Granbury TX
Granbury TX
Thank you guys.
Assuming the magnum has the 5/16 balve guide.
I just picked up a 5.9 tonight and will definitely be going with bigger cam.
02 Mercedes C230K
19 Camry
Re: Cylinder head tool recommendation please [Re: Prochargedmopar] #2486840
04/23/18 02:44 PM
04/23/18 02:44 PM
I bought all of the tools I needed and seals from Goodson to do all the early BB, SB and 426 Hemi Mopar motors along with a couple of the 11/32 guide to work on the after market BB aluminum heads with those size guides along with the spring pocket cutters also thumbs
Re: Cylinder head tool recommendation please [Re: Cab_Burge] #2486857
04/23/18 03:22 PM
04/23/18 03:22 PM
an8sec70cuda Offline
iagree Goodson is great to deal with.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Cylinder head tool recommendation please [Re: an8sec70cuda] #2486869
04/23/18 04:20 PM
04/23/18 04:20 PM
PA.
"Little"John
"Little"John
PA.
Yes they are. NEVER an issue with them.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Cylinder head tool recommendation please [Re: pittsburghracer] #2486898
04/23/18 05:10 PM
04/23/18 05:10 PM
dogdays Offline
dogdays  Offline
The cutter trims the valve guide and cuts the guide OD for the seal of your choice. You should know the OD your preferred seal requires before you buy the cutter. For me it was 0.625 so I could use stock late LA valve seals.
If the cutter is any good it'll have carbide cutting tips. Actually I've never seen one that didn't. These stay sharp a long time but crack easily. I dropped the cutter attached to the pilot which slid down the valve guide. The cutter cracked, part broke off. So now when I cut down a guide there is a little 1/32" thick cylinder of the original guide that I have to trim off with a grinder.
R.
