Re: How to test the sure-grip unit in a DANA 60 for function?
[Re: Dixie]
#2486293
04/22/18 02:42 AM
04/22/18 02:42 AM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Block one wheel so it can't turn and use a beam torque wrench on the other side to see how much torque it takes to turn the axle. If it takes 100 ft. lbs. or more to turn the axle the unit is good.
Might have to get creative to figure how to turn the axle with the torque wrench.
[Re: Dixie]
#2486326
04/22/18 10:40 AM
04/22/18 10:40 AM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: Dixie]
#2486347
04/22/18 11:43 AM
04/22/18 11:43 AM
Posts: 953 Chicago
PurpleBeeper
Chicago
I have to go with bad340fish on this one....much easier and a lot more fun.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Dixie]
#2486454
04/22/18 04:54 PM
04/22/18 04:54 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
The reason I'm asking is I hammered the car and it only left a one legger. I bought the Dana used 10+ years ago and didn't check it prior to installation. I'm wondering if it's time for a rebuild.
Thanks John, I'll see what I can rig up. 100 ft lbs sounds kinda light. Not that I'm any sort of expert.
[Re: Dixie]
#2486457
04/22/18 05:00 PM
04/22/18 05:00 PM
John_Kunkel
Rio Linda, CA
100 ft. lbs. would be the minimum, the good ones I've tested held tight at 150 ft. lbs.
[Re: Dixie]
#2486504
04/22/18 07:22 PM
04/22/18 07:22 PM
Posts: 21,808 Kirkland, Washington
Pacnorthcuda
Thanks John, I'll see what I can rig up. 100 ft lbs sounds kinda light. Not that I'm any sort of expert. It needs a rebuild.
[Re: Pacnorthcuda]
#2486513
04/22/18 07:50 PM
04/22/18 07:50 PM
Dixie
Thanks John, I'll see what I can rig up. 100 ft lbs sounds kinda light. Not that I'm any sort of expert. It needs a rebuild. that's what I'm thinking, just want to be sure.
[Re: Dixie]
#2486549
04/22/18 09:06 PM
04/22/18 09:06 PM
Posts: 10,549 Rittman Ohio
fourgearsavoy
Rittman Ohio
I would say it might not even be a sure-grip Just grab a ratchet and pull the cover because you're gonna need to know what you have for the re-build anyway Take you less than 10 minutes Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
