70 Super Bee Jack #2486017
04/21/18 11:49 AM
04/21/18 11:49 AM
Arizona
jrp16 Offline OP
jrp16  Offline OP
Arizona
Anyone have a picture of a restored bumper jack for a 70 Coronet Super Bee?
Also need to know the correct shades of paint to use.
Thank you!
Re: 70 Super Bee Jack [Re: jrp16] #2486068
04/21/18 02:15 PM
04/21/18 02:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thank you!
Here ya go.... http://www.nicksgarage.com/jacks.htm
Re: 70 Super Bee Jack [Re: DAYCLONA] #2486111
04/21/18 04:33 PM
04/21/18 04:33 PM
Arizona
jrp16 Offline OP
jrp16  Offline OP
Arizona
Thank you!
Any idea what shade of gray that is?
Re: 70 Super Bee Jack [Re: jrp16] #2486127
04/21/18 05:19 PM
04/21/18 05:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thank you!
There's "50 shades of gray" that you could buy that will match closely in spray can formulas
Totally Auto sells a spray can formula just for Mopar gray jack color matching
Most spray can paint stuff today totally sucks due to VOC compliance, so depending on how detail/quality oriented you are, you could have your local paint jobber mix a quality paint to gun spray once you've determined a correct match hopefully from an actual jack component, choice is endless...
Re: 70 Super Bee Jack [Re: jrp16] #2486130
04/21/18 05:23 PM
04/21/18 05:23 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Thank you!
As Mike mentioned there is a paint from Totally Auto
Also "Dove Gray" by Krylon works pretty good.
If you need exact there is Frank Baddleson at Roger Gibson restoration that sells spot enamel that you will need to shoot with a spray gun.
Re: 70 Super Bee Jack [Re: jrp16] #2486711
04/23/18 05:09 AM
04/23/18 05:09 AM
between the coasts
4mayhemi Offline
4mayhemi  Offline
between the coasts
I think there are lots of threads here on jack restoration, mostly for e-bodies. Same thing though.
