#2485951 - 04/21/18 06:27 AM Non Mopar...but, WOW
oldjonny Offline
Don't argue with me.
Loc: Michigan
At least he uses the word 'roughly' multiple times. I would switch up the context of where to apply the word though as 'roughly' certainly does apply. What would cause something like this? Friends get together and while inhaling copious amount of beer come up with an idea?
https://saginaw.craigslist.org/cto/d/1955-chevy/6567033112.html
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
#2485985 - 04/21/18 08:28 AM Re: Non Mopar...but, WOW [Re: oldjonny]
NTOLERANCE Offline
Loc: Madison Wi
Seen this mod a few times with tri-five cars . Hack the back doors out of a four door to make it a two door
Always thought it looked horrible.
#2485995 - 04/21/18 08:43 AM Re: Non Mopar...but, WOW [Re: oldjonny]
moparjim79 Offline
Loc: Central Pa
Theres one on harrisburg craigslist.
#2486065 - 04/21/18 12:09 PM Re: Non Mopar...but, WOW [Re: NTOLERANCE]
nuthinbutmopar Offline
Loc: Central Michigan
Seen it on VW busses, too. Co-worker bought a '58 or '59 that was chopped down to make a parade car and put a good center section back in. Doubt that's possible here...
#2486071 - 04/21/18 12:25 PM Re: Non Mopar...but, WOW [Re: oldjonny]
Morty426 Offline
Loc: Sacramento CA
How many clowns can fit in that?
#2486074 - 04/21/18 12:30 PM Re: Non Mopar...but, WOW [Re: oldjonny]
wannadrag Offline
Loc: WI
Looks better done on this 55 than it does on a 57.
#2486094 - 04/21/18 01:07 PM Re: Non Mopar...but, WOW [Re: Morty426]
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Loc: Puttin' on the foil in Charles...
The guy that built it, for starters.
Earning every penny of that moderator paycheck.
DBAP
#2486098 - 04/21/18 01:27 PM Re: Non Mopar...but, WOW [Re: oldjonny]
Grizzly Offline
Loc: at work
Not only do we have bad taste in looks, but we got the engine covered too:
"301 cu.in. 12.5 compresion, Alum. Brodix 2.08 intake valve, 8,500 RPM Comp. Cam., Holley double pumper"
Boy, would that ever be a fun engine at anything less than 25,000 rpm.
Idiot.
Here's his other car:
#2486144 - 04/21/18 04:01 PM Re: Non Mopar...but, WOW [Re: not_a_charger]
Morty426 Offline
Loc: Sacramento CA
Why am I imagining Krusty the Klown built this?
#2486168 - 04/21/18 05:42 PM Re: Non Mopar...but, WOW [Re: Morty426]
6bblFLASH Offline
Loc: N.E. Ohio
Short Hot Rod for the guy that rode the SHORT BUS to school.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
#2486377 - 04/22/18 10:57 AM Re: Non Mopar...but, WOW [Re: oldjonny]
Soopernaut Online   content
Loc: Des Moines IA
Chevelle version...
https://desmoines.craigslist.org/cto/d/68-custom-chevelle/6568046499.html
\Grabs your attention, doesn't it! Not for the bashful, 'cause EVERYBODY wants to ask about it, like- what the 'ell is it?. . .short story is it was a 4 door and somebody cut out from the back of front seat back to the package tray. Now it has 2 bucket seats with a console and the shifter in the console. Very similar to an El Camino. I've had it up on a lift and whoever did it did a good job. The frame is solid and it appears the floor pans have been replaced and it has been undercoated at some point. It has a strong running 327, Edelbrock intake & 4bl carb, AT-probably TH350. Had my mechanic go through it last fall: tune-up, oil change, carb adjusted, brakes checked, and road tested. Right now it's a daily-driver, but there are a few areas that need attention. Also, it's a "20-footer" due to some rust bubbles under the paint in the usual areas--see the pictures. Has some SS badging, but is NOT a SS. Tires are near new! Calls taken after noon and evening.
1970 Dodge d100/eventually going on a 77 D100 frame
#2486411 - 04/22/18 12:27 PM Re: Non Mopar...but, WOW [Re: Soopernaut]
oldjonny Offline
Loc: Michigan
Originally Posted By Soopernaut
Chevelle version...
WOW...what a steaming pile of dung that one is.
#2486413 - 04/22/18 12:32 PM Re: Non Mopar...but, WOW [Re: oldjonny]
Silver70 Offline
Loc: Rust Belt, SW PA
That would not be fun just getting in and out of... not to mention ho ugly it is!
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
99 Trans Am, 66 GTO, 06 Magnum RT AWD
#2486448 - 04/22/18 02:24 PM Re: Non Mopar...but, WOW [Re: oldjonny]
Iowan Offline
Loc: Lost in Time
Must be a bowtie thing, I know a guy with a 64 Impala doing the same thing.
To me it's a why bother thing but oh well.
Have a great day
Iowan
"obsolete is neat, the older I get the better I was"
#2486481 - 04/22/18 04:16 PM Re: Non Mopar...but, WOW [Re: Iowan]
John Brown Offline
Loc: South Bend
The only ones I have seen that had proportions anywhere near right were shortened wagons. Shorty more door sedans pretty much stink on ice.
#2486548 - 04/22/18 07:04 PM Re: Non Mopar...but, WOW [Re: Grizzly]
NTOLERANCE Offline
Loc: Madison Wi
I’m by no means a Chevy fan but a 301 is a pretty cool old school drag engine. Yes. You can make more power with other engines.
Yes you spin a 301 8000-9000 rpms. Below 4500? Not much going on.
Friend of mine has built a few for his tri-five gassers. Runs 11’s with a stick. (A833 trans)
Here’s one of his builds.
https://www.jalopyjournal.com/forum/thre...r-build.453142/
Vid
https://m.youtube.com/watch?v=P_sYOoOxy2k
#2486704 - 04/23/18 02:05 AM Re: Non Mopar...but, WOW [Re: NTOLERANCE]
OhioMopar Offline
Loc: Mt.Gilead, Ohio
You're not the only one...
Looking for my original 383 block. Last seen around the Atlanta area. 7449 are the last 4 of the VIN.
#2486705 - 04/23/18 02:06 AM Re: Non Mopar...but, WOW [Re: Grizzly]
OhioMopar Offline
Idiot.
Clearly he enjoys attention.
25,705 Registered Members
196,819 Topics
Okay, so it's NOT a Mopar...
by rrbrucea
01/21/19 08:46 PM
Can you make a Dominator carb streetable?
by GY3
01/21/19 08:40 PM
Sputter / backfire FiTech fuel injection
by BDW
01/21/19 08:29 PM
Worst dragracer ever
by BloFish
01/21/19 08:26 PM
