anyway to install hellcrate without aftermarket fr susp? #2476735
04/03/18 01:13 PM
04/03/18 01:13 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
I think the hellcrate is an absolute bargain and am ready to buy but the 4-5k for the seemingly required aftermarket front steering/suspension/crossmember kills my wallet.
Is it 100% required? can a guy cut/hack modify the existing mopar parts to work?
Re: anyway to install hellcrate without aftermarket fr susp? [Re: ogopogo] #2476742
04/03/18 01:26 PM
04/03/18 01:26 PM
USA
hudsonhornet7x Offline
USA
The only sticking point I can see is the hellcat specific oil pan and front cover may interfere with the front of the K frame. Of course the K frame could be notched to make it work.
Re: anyway to install hellcrate without aftermarket fr susp? [Re: ogopogo] #2477051
04/03/18 09:45 PM
04/03/18 09:45 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Why? the hellcat engine is the same block as any G3. In a A B E body you will need to make mounts or buy them and change the oil pan to fit.
Or I'm I missing something?
Matt
Re: anyway to install hellcrate without aftermarket fr susp? [Re: ogopogo] #2477059
04/03/18 10:04 PM
04/03/18 10:04 PM
USA
USA
I believe the front cover of a hellcat and the front of the oil pan of a hellcat are a little different than the rest of the G3 family. Or so I have been told. In other words an aftermarket oil pan and a hellcat timing cover may not play nice with each other.
Re: anyway to install hellcrate without aftermarket fr susp? [Re: hudsonhornet7x] #2477142
04/04/18 12:15 AM
04/04/18 12:15 AM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
I used a Hemi Jeep oil pan, rear sump, on our Hellcat swap. You have to trim a little off the front lip and drill two holes to mate up with the Hellcat cover. Worked out fine.
Re: anyway to install hellcrate without aftermarket fr susp? [Re: AeroMonte] #2477143
04/04/18 12:16 AM
04/04/18 12:16 AM
USA
USA
That is great to hear!! I am not that far along in our project yet. Thanks for sharing.
Re: anyway to install hellcrate without aftermarket fr susp? [Re: ogopogo] #2477157
04/04/18 12:41 AM
04/04/18 12:41 AM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
Jeep pan on the Hellcat
Re: anyway to install hellcrate without aftermarket fr susp? [Re: ogopogo] #2477514
04/04/18 07:27 PM
04/04/18 07:27 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Couple places make mounts that will allow it to bolt right in a stock Mopar front end. Its much tricier if you want to put an engine plate in to mount it like I do.
I also agree, its a a very good bargain. Indy and MagnumForce I believe sell the mounts. And Milodon sells the pan....
Re: anyway to install hellcrate without aftermarket fr susp? [Re: ogopogo] #2477561
04/04/18 09:10 PM
04/04/18 09:10 PM
Ontario, Canada
75DartHang10 Offline
Ontario, Canada
please post up any direct links to swap parts etc to help the rest of us out.
Re: anyway to install hellcrate without aftermarket fr susp? [Re: AeroMonte] #2485178
04/19/18 05:02 PM
04/19/18 05:02 PM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
Have you tried to fit a mini starter yet. Sounds like we may need to grind off the excess part of the pan the and block to make it fit..
Re: anyway to install hellcrate without aftermarket fr susp? [Re: AeroMonte] #2485295
04/19/18 09:57 PM
04/19/18 09:57 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Who made the engine mounts?
Matt
Re: anyway to install hellcrate without aftermarket fr susp? [Re: MattW] #2485342
04/19/18 11:43 PM
04/19/18 11:43 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
Matt
Got the mounts from RMS in Pa. I'm using the starter that came with the Hellcat engine. Already test fit it.
Re: anyway to install hellcrate without aftermarket fr susp? [Re: ogopogo] #2485354
04/20/18 12:04 AM
04/20/18 12:04 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
What side of the engine is the starter designed to mount on?
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: anyway to install hellcrate without aftermarket fr susp? [Re: Silver70] #2485482
04/20/18 09:40 AM
04/20/18 09:40 AM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
I used a GM 4L80 race prepped automatic, modified with a Reid Mopar bellhousing. It is made so the starter can mount on either side but I am using the stock location on the passenger side. With the Hellcat brake booster and stock exhaust manifolds, it's getting crowded on the drivers side.
