Re: Late HEMI in 2000 Dakota swap
[Re: Dr Dave]
#2484685
04/18/18 04:20 PM
04/18/18 04:20 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
not going to be smog legal, the trans and t case should be ok for a while. It will not be an easy swap, the harness and computer need to be swapped to the 03 up 4 plug computer set up, that will require dash and interior ABS and SRS computers and that will require a swap to the 01 up interior. Your best bet is to start with the 03-04 dakota or at least a donor for all the stuff. You will need to fab an oil pan unless there is an after market one I am un aware of and you will need a mechanical throttle body big enough to feed the hemi, the 4.7 one could be adapted but would be pretty small even on the mildest 5.7. The motor mounts for a 4x4 still need to be fabbed, I don't know of anyone making one yet. If you had the later 03-04 computer system you might be able to get a 5.7 computer from a 1/2 ton of the same year, do some wiring harness mods to run the throttle by wire and finger out how to mount the gas pedal to match, then if both the truck and donor computer do not have factory security they would probably be happy enough together.
[Re: Dr Dave]
#2484703
04/18/18 05:16 PM
04/18/18 05:16 PM
Posts: 280 GEORGIA
barracuda7199
GEORGIA
Well, that’s not looking too feasable for me. I’m wondering if the 318/360 Magnum is a more sensible swap for this application? Thoughts?? That’s not easy either. Different transmission and wiring harnesses are way different. The a/c compressor is on different sides as well. Best bet is fix the 4.7 or move on if your not ready for a major project not for the faint of heart. It can be done do a google search there are several guys who have done the hemi swap.
[Re: Dr Dave]
#2484710
04/18/18 05:38 PM
04/18/18 05:38 PM
HotRodDave
Kalispell Mt.
probably the best/simplest thing you can do with your lemon is make lemonade, swap in a good used HO 4.7 and do new timing chains, guides, tensioners, oil pimp water pimp and head gaskets (you can get a front of the engine kit off fleabay for under $150 plus the head gaskets). They make 265 HP and the extra 30 HP over your stock engine is very noticable. Should be good to go for another 100,000 if the bottom end is decent. Anything 02 or older should be a bolt in. The HO engine has forged crank, dome pistons, bigger cams and supposedly bigger intake though I don't see any difference between it and a regular one except the HO stamped on them, same as the heads. Even if you chose to fix up your old engine with the chains and such that I mentioned then the HO cams are an easy and noticable upgrade at that time.
[Re: Dr Dave]
#2484837
04/18/18 10:00 PM
04/18/18 10:00 PM
Posts: 2,724 541 slobovia
A990
541 slobovia
Heres some reading 5.7 into 4x4 Dakota This is a massive post. There's a guy in Arizona building pans and mounts specifically for the 4x4s Hotwire Auto has decent information about electronics Mopar engine swaps bus info I'm looking into this to do in the next year or so.
[Re: A990]
#2485442
04/20/18 04:17 AM
04/20/18 04:17 AM
Posts: 235 Oregon
Dr Dave
