leaf springs for street strip car
#2485065
04/19/18 12:57 PM
04/19/18 12:57 PM
Posts: 1,169 clarks summit pa
73cuda340
clarks summit pa
I'm looking at replacing the original springs on my 73 cuda. The car squats noticeably in the rear. What seems to be the opinion on the best setup for a street strip car? The car is a 528 hemi with a 4 speed, so I want something that will help it hook. I don't want any of the springs that lower the rear that I see everywhere, but at the same time I don't want the back of the car to have a huge amount rake to it either. I don't mind if the car has a rough ride to it. I've read mixed reviews on the super stocks and caltracs. I understand the caltracs will give a slight E.T. improvement, but I don't really want to have the bars hanging doen low and causing any ground clearance issues.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: leaf springs for street strip car
[Re: Porter67]
#2485119
04/19/18 03:02 PM
04/19/18 03:02 PM
Posts: 4,664 Wichita
GY3
Wichita
The Cal-Trac bars don't hang down and cause any ground clearance on my car. I did the super stock spring thing and they wear out after about a year and completely lose their arch.
I run mine all over on the street with Cal-tracs and love them!
[Re: GY3]
#2485124
04/19/18 03:09 PM
04/19/18 03:09 PM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
I run mine all over on the street with Cal-tracs and love them! Same here. Cal-Tracs or Assassin Bars (very similar to Cal-Tracs) are as good as it gets for leaf spring traction. Both are about the same as far as ground clearance. I've never had a clearance issue w/ mine.
[Re: an8sec70cuda]
#2485263
04/19/18 08:51 PM
04/19/18 08:51 PM
73cuda340
clarks summit pa
Do the caltrac mono leafs bolt right up, or are different hangers required? How is the handling?
[Re: Cab_Burge]
#2485398
04/20/18 01:16 AM
04/20/18 01:16 AM
GY3
Wichita
Yep, I had to step up to a Dana 60 and 1350 u-joints. My car kept finding the weak points in the drivetrain last summer. Get a rear yoke that uses u-bolts while you are at it. Sticky tires and power find the weak links. 4 speeds make it worse.
[Re: calrobb2000]
#2485399
04/20/18 01:18 AM
04/20/18 01:18 AM
GY3
Wichita
hi i have a 73 cuda not the fastest car ever 12.31 @ 110 .
i installed 460 & 461 ss springs in 1986 and they work perfect and have never saged !
type in, mason dixon mopar 2017 cuda and you can see me make a few runs. The early Made In America ones were great. The current ones are made in Mexico. They lose arch quickly. It is well documented.
[Re: 73cuda340]
#2485416
04/20/18 02:00 AM
04/20/18 02:00 AM
GY3
Wichita
Do the caltrac mono leafs bolt right up, or are different hangers required? How is the handling? Yes, they bolt in. I live out here in the Kansas flatlands so about all the "handling" I see is highway on ramps. That said, I have no complaints. They will make some "clicking" noises as they articulate. Nothing too annyoying, though.
[Re: Wailin D]
#2485510
04/20/18 11:14 AM
04/20/18 11:14 AM
73cuda340
clarks summit pa
I plan on putting a dana 60 in as well, just haven't gotten to it yet.
[Re: 340Cuda]
#2485850
04/20/18 11:05 PM
04/20/18 11:05 PM
73cuda340
clarks summit pa
How do the mono leafs handle on the street in corners?
[Re: 73cuda340]
#2486626
04/23/18 12:16 AM
04/23/18 12:16 AM
73cuda340
clarks summit pa
Does anybody run these on the street?
[Re: Cab_Burge]
#2486700
04/23/18 03:32 AM
04/23/18 03:32 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Of course you must remember also that your right foot controls how much power the engine feeds to the drivetrain Good luck either way When you have pets, you have to let them eat LOL
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: an8sec70cuda]
#2486715
04/23/18 05:28 AM
04/23/18 05:28 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Same here. Cal-Tracs or Assassin Bars (very similar to Cal-Tracs) are as good as it gets for leaf spring traction. Both are about the same as far as ground clearance. I've never had a clearance issue w/ mine. What springs did you run with your Assassin Bars?
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: OhioMopar]
#2486779
04/23/18 12:41 PM
04/23/18 12:41 PM
an8sec70cuda
Same here. Cal-Tracs or Assassin Bars (very similar to Cal-Tracs) are as good as it gets for leaf spring traction. Both are about the same as far as ground clearance. I've never had a clearance issue w/ mine. What springs did you run with your Assassin Bars? I have Cal-Tracs. The Calvert mono springs handle just fine on the street. I've out a bunch of miles on mine. Don't bother putting "good parts" in the 8.75. There's nothing you can do to fix what's weak. After you twist the axles, you'll break the diff, then you'll break the gear, then the main caps. Somewhere in there the housing will get bent. Save your money for a Dana if you ever plan on getting the thing to hook. Keep in on the street spinning the tires and the 8.75 will probably live a long time.
[Re: an8sec70cuda]
#2486876
04/23/18 04:32 PM
04/23/18 04:32 PM
OhioMopar
Mt.Gilead, Ohio
Same here. Cal-Tracs or Assassin Bars (very similar to Cal-Tracs) are as good as it gets for leaf spring traction. Both are about the same as far as ground clearance. I've never had a clearance issue w/ mine. What springs did you run with your Assassin Bars? I have Cal-Tracs. The Calvert mono springs handle just fine on the street. I've out a bunch of miles on mine. I'm sorry, I misread. I would like to run Assassin bars, but I have Super Stock springs now. I'm not sure if it would be wise to run those with the Assassins or not. I know you "can", the question is "should I"! I haven't decided against Caltracs, I just would like to run Assassin Bars. (I already have the Dana)
[Re: OhioMopar]
#2486883
04/23/18 04:40 PM
04/23/18 04:40 PM
an8sec70cuda
Same here. Cal-Tracs or Assassin Bars (very similar to Cal-Tracs) are as good as it gets for leaf spring traction. Both are about the same as far as ground clearance. I've never had a clearance issue w/ mine. What springs did you run with your Assassin Bars? I have Cal-Tracs. The Calvert mono springs handle just fine on the street. I've out a bunch of miles on mine. I'm sorry, I misread. I would like to run Assassin bars, but I have Super Stock springs now. I'm not sure if it would be wise to run those with the Assassins or not. I know you "can", the question is "should I"! I haven't decided against Caltracs, I just would like to run Assassin Bars. (I already have the Dana) The Assassin bars work on the same principle as Cal-Tracs, just have a slightly different design and more adjustments. I would not run them w/ SS springs...get the Calvert mono springs.
