washer pump #2485059
04/19/18 12:44 PM
04/19/18 12:44 PM
ny
marcjames Offline OP
ny
1967 gtx put new washer pump in one wire is ground the other plugs into what color wire brown or green thanks
Re: washer pump [Re: marcjames] #2486021
04/21/18 11:56 AM
04/21/18 11:56 AM
www.mymopar.com MIGHT show it or push the button/switch & see which wire is hot.
Re: washer pump [Re: marcjames] #2486082
04/21/18 02:47 PM
04/21/18 02:47 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Brown is the washer pump wire. Is your harness cut? They are all coming out of the harness where they plug in so it should be easy to see what goes where.
The green comes out of the hon relay with 2 short wires at plug into the horns. Running to the horn relay from bulkhead are 2 wires: black/white tracer and purple.
Confusing this is also a purple for temp sender, and green for alt field wire.
Re: washer pump [Re: marcjames] #2486176
04/21/18 08:29 PM
04/21/18 08:29 PM
ny
ny
yes NANKET you are correct green horn relay no harness is not cut the brown wire with plug is right there from pump where does the black wire go to screw on washer bottle is there a fuse I should look for THANKS MARK
