Putting the rear main in backwards works well at increasing vacuum, as long as your rear cap has good drain out. I've done it on several builds with great results as long as you always run a pump. The last one I did was an indy aluminum hemi block, and the thing leaked like there was no seal in it. Turned out the oil from the bearing was shooting past it.
