Cool carb #2483994
04/17/18 01:11 AM
04/17/18 01:11 AM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
Anyone use it, or have an opinion on its effectiveness to keep heat away from the carb?
http://www.coolcarb.com/order-products.html
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Cool carb [Re: BloFish] #2484068
04/17/18 09:42 AM
04/17/18 09:42 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Holley sold something like that a long time ago. As to the effectiveness on a carb drag car, if it were worth its weight in power, every PS car (before efi) would have ran it, or something like it. JMO
Another reason I'm deeply saddened by the current state of PS. Anyting you ever wondered about working or not could be summed up by a walk through the PS pits lol. Free, accurate, tried and true R+D.
Re: Cool carb [Re: BloFish] #2484117
04/17/18 11:18 AM
04/17/18 11:18 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
PS cars don't run long enough to worry about heat soak. The real test is NASCAR.
Re: Cool carb [Re: Stanton] #2484122
04/17/18 11:28 AM
04/17/18 11:28 AM
tboomer Online work
tboomer  Online Work
What is Eledbrock? shruggy
Re: Cool carb [Re: tboomer] #2484464
04/18/18 01:20 AM
04/18/18 01:20 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
It’s just another way of saying “elderbrock”. 😆
Re: Cool carb [Re: BloFish] #2484468
04/18/18 01:32 AM
04/18/18 01:32 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I just use a small plastic "phenolic" spacer.
Re: Cool carb [Re: BloFish] #2484843
04/18/18 10:16 PM
04/18/18 10:16 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I have been running a Cool Carb heat shield and two spacers for 5 years now on my street 340. You can definitely feel a difference in the temp of the bowls before and after. But you have to be careful because they have a max temp of around 275-300 degrees. They will melt if you get them too hot which another member showed me back when I was looking into buying. But mine still look to be in great shape when I last took the carb off over this Winter.
Re: Cool carb [Re: BloFish] #2484863
04/18/18 10:48 PM
04/18/18 10:48 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I met the owner at Carlisle and tried them.I will say they are a great product, and great customer service.
Re: Cool carb [Re: BloFish] #2484945
04/19/18 05:13 AM
04/19/18 05:13 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Not knocking this product but I found 2 things that help. You can buy an aftermarket carb/manifold gasket that has and aluminum layer placed between the the gasket layers, slightly thicker than factory gasket(double up on the gaskets works better) and the other is to wrap the carb studs or bolts with LP teflon tape. LP tape is thicker than regular teflon pipe tape. Stops the heat from wicking up from the intake to the studs and then the carb. Simple and effective.
