Re: Drilling leaf springs
[Re: Clanton]
#2492378
05/05/18 11:47 AM
05/05/18 11:47 AM
Posts: 8,031 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Ok, i have some pics. now, from the base of that slip shaft to the edge of the boot measures 2", but the main shaft is out past the boot 1/4".
[Re: mopar dave]
#2492571
05/05/18 10:45 PM
05/05/18 10:45 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
couple more. The u joint measures 3" from the pinion saddle. So that 3" is with the yoke all the way in the trans?
[Re: mopar dave]
#2492576
05/05/18 11:02 PM
05/05/18 11:02 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
what length of drive shaft should i order? If you order from Dr. Diff, he asks for two measurements, and some other questions, of course. But Idk if you have to call to have something other than a 1350 joint shaft made.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: Clanton]
#2492590
05/05/18 11:27 PM
05/05/18 11:27 PM
mopar dave
Mt Morris Michigan
yes, with it all the way into the trans. I calculate 2 3/4 of spline engagement statically. Probably 3" under load. Enough or do i need a new drive shaft?
[Re: mopar dave]
#2493246
05/07/18 03:58 PM
05/07/18 03:58 PM
Clanton
northern,Ohio,USA
Thank you for your information you got!How much do you think a new shaft with ends and joints will cost?250$Wait I bet with new ends,ballance will be more like 350$
