Re: Drilling leaf springs
[Re: Clanton]
#2484299
04/17/18 05:39 PM
04/17/18 05:39 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
I dont think the link bars will be an issue, but the yoke might as its already out further than recommend. Whats the recommended? 3/4"? I think mines currently 1". Will have to remeasure everything. Good call. Thanks Good time to come out with the u-joint spacer 1/2" lol just kidding.The brake hose may be short,The axle twist may hit the shock,Drive shaft may be too short.Nothing simple. Beat the heck out of the front wheel well for clearance, every Mopar stocker does that to get the 30" tire to fit.
[Re: mopar dave]
#2484363
04/17/18 08:31 PM
04/17/18 08:31 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Beat the heck out of the front wheel well for clearance, every Mopar stocker does that to get the 30" tire to fit. Sir, please step away from the BFH
[Re: mopar dave]
#2484394
04/17/18 09:57 PM
04/17/18 09:57 PM
cudaman1969
fredericksburg,va
Not the inner thats the problem. Its the outer wheel well lip. 3/4" of clearance and i'm getting 1" taller tires. I think tire would look better centered in the opening as well. Didn't really mean the inner, just a phrase. The lip is what I meant, moved mine 1-1/2 " foward at the rocker, on a smooth arc from the top, cut it out, slice it down, weld back. I used the rear lip of an old set of front fenders.
[Re: mopar dave]
#2485998
04/21/18 10:54 AM
04/21/18 10:54 AM
Posts: 8,031 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Measured everything up to get pinion angle. Looks like i have 1* pinion angle according to the spicer calculator. http://spicerparts.com/calculators/driveline-operating-angle-calculator I only have a couple drill bits that will drill thru the springs. The larger bits will not. I'll have to take them to the machine shop to get them finished. The front segments on the car have a 1.5" arch and the ones replacing them have a 2" arch, so will the 2" arch spring set the ride height higher?
[Re: Clanton]
#2486159
04/21/18 06:55 PM
04/21/18 06:55 PM
mopar dave
Mt Morris Michigan
Those pics are before i started. I was only able to drill up to 1/4", after that drills would not cut. Gonna go look for some different drill bits tomorrow. I'm stopped for now. I pulled these springs out not paying attention to what spring came from what side. mixed up now. are they right and left side specific?
