Re: Rear Wilwoods, 8-3/4" w/Brake Pad Knockback
[Re: Mopar72Man]
#2483947
04/16/18 11:30 PM
04/16/18 11:30 PM
Posts: 562 Ohio
lockjaw-express
Ohio
The number 2 retainers holds the snap ring in place, then once you start driving, the splines will lock/bind up and hold...just like a Ford 9”.
The design of the Wilwood kit sucks, but it works OK. Also, either you need to remove the center button/thrust slug from the differential...or, what I did, was have a precision grinding shop take off 1/16” off the end of each axle, still leaving a little chamfer.
But, if you have some free play, you will be ok.
Mark
[Re: BigBlockMopar]
#2484364
04/17/18 08:31 PM
04/17/18 08:31 PM
Posts: 803 Oklahoma
Mopar72Man
Oklahoma
With green bearings you'll only get play at the axles if the bearings are worn. The bearing itself is held in place by the snapring.
Do you have a residual valve installed in/near the MC for the rear brake line?
If the retaining plate [#2] from Wilwood is not up against the bearing well, couldn't the bearing move within the housing? I do not have a residual valve in but was planning on putting one in the rear of the car, near the rubber line fitting. I have a 10# valve on the shelf.
72 Challenger - will be sublime, little 340 904, 8 3/4" - Under Construction
[Re: Mopar72Man]
#2485954
04/21/18 08:53 AM
04/21/18 08:53 AM
Posts: 5,764 ohio
ruderunner
ohio
Imho, 10# will be too much, I wouldn't use any rpv with disc brakes.
As stated the green bearings shouldn't have any play.
It's likely that they are sliding in the housing, no bueno they will wear the housing. Maybe see about some shims to sandwich the snap ring between the housing and retainer. Maybe a spacer sleeve to fit in the housing bore to hold the bearing against the retainer?
Angry white pureblood male
