Page 1 of 2 1 2 >
#2475812 - 04/01/18 11:31 PM For Sale - Small Block Engine - 2nd Quarter
moparts Offline
#2475927 - 04/02/18 09:08 AM Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
Cal Custom El Toro air cleaner wing nut. $5
Used chrome thermostat housing. $5
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner hose. $20
Original Cal Custom 14" finned aluminum air cleaner with filter. $100
Original Cal Custom 9" finned air cleaner top and base. No filter. $75
1970 Style single nipple oil breather with hose. $35
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $60
AC alternator bracket from a mid 70s 360. $15
Good used intake to water pump crossover hose from a mid 70s 360 with AC. $5
Small block passenger side biscuit motor mount bracket. $30
137 New Spectre brand radiator and heater hose clamp covers. Some chrome, some red and some blue anodized. Various sizes. $50 for the lot.
New Cloyes C-3028 small block Mopar timing chain. $25
Carb. throttle linkage stud. $10
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
Pair of factory small block valve covers. Not sure of year. Nice shape. $75
Email: gt340 @ yahoo.com
Edited by 6PAX (04/16/18 02:46 PM)
#2476004 - 04/02/18 10:23 AM 408 Street/Strip pump gas small block [Re: moparts]
WadeMetzinger Offline
Loc: Tulsa, Ok
Mopar 408 stroker (1974 360 block, decked, squared, align honed, ARP head bolts, main studs, new cam bearings and freeze plugs) Scat 4" cast crank, Scat rods, Icon forged pistons, sidewinder Larry Smith stage 1 ported heads, Comp .501 Hyd cam, Air Gap intake, Crane ductile rockers, SFI Ballancer, aluminum valve covers. 10.5:1 pump gas friendly, street/strip motor. Pre-oiled and ready to go. Should make 450-475 hp
Call, text or email 918-809-0987 or wametzinger@yahoo.com
$7,500 Firm (link to build sheet below)
Link to more pictures: Additional pictures
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.70@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
#2476798 - 04/03/18 01:20 PM Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts]
BLACKHEMIRR Offline
6138S Thermoquad, 1972 340 manual trans, complete rebuildable carb, asking $135.
6318S Thermoquad, 1973 340 manual trans, baseplate and airhorn only (no plastic center), asking $100.
1406 Edelbrock AFB, no choke assembly, asking $75.
All prices plus shipping. PM me here if interested. Thanks
#2477709 - 04/04/18 11:59 PM Re: For Sale - Small Block Engine - 2nd Quarter [Re: BLACKHEMIRR]
Super 70 Offline
Loc: Heart of Iowa
For Sale: New, never run Comp Cam Hydraulic Roller cam. I have the original box to go with it. It the 264 HR-12 roller cam. It is more designed for a computer controlled Magnum engine but could be used in any small block Mopar as long as you had the correct lifters. The specs. are as follows: Lobe separation 112, intake duration at .050 lift -210 degrees, duration on the exhaust side - 220 degrees, total lift on both sides .512, lobe lift -.320 This cams runs about $350.00 new. Asking $175.00 PM me here or E-mail me at cloudone.70@gmail.com
#2478839 - 04/07/18 12:18 PM Re: For Sale - Small Block Engine - 2nd Quarter [Re: Super 70]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
2 NOS MOPAR IGNITION CONDENSERS CH-108/3420600
#2875939 WITH PENTASTAR , WITH # ON IT
FITS DODGE&PLYMOUTH CAST IRON DISTRIBUTORS,273-340 AND 340+6 DUAL POINT DISTRIBUTORS.
$25
cowgerwilliam035@gmail.com
#2479657 - 04/08/18 08:29 PM Small block Crane 1.6 rockers and shafts [Re: moparts]
kenworth_goose Offline
Loc: ky.
I have a new set of Crane 1.6 roller rockers for a small block. What you see is what you get. 350.00. These are over 500.00 new. These are new and unused. PM me. Thanks
#2480423 - 04/10/18 10:12 AM Re: 318 - 360 exhaust manifold [Re: kenworth_goose]
moparx Offline
Loc: north of coder
For Sale : 318/360 driver side exhaust manifold. part# : 3870337-2. cast date : 6-28-77.
was taken off a 360 replacement engine when new in 1978. lightly blasted, primed, then stuck on the shelf until garage clean-out now. no charge for the storage dust and dirt ! biggrin not sure what body this fits, although i suspect something like a diplomat. asking $65 plus the ride. paypal +3% or "friends & family", check, MO, whatever works for you ! other pics available for your inspection. just ask.
PM me here, or : moparx [AT] windstream [DOT] net
THANK YOU MOPARTS for the add ! bow
beer
Edited by moparx (04/10/18 10:21 AM)
#2481033 - 04/11/18 10:39 AM For Sale Good Running 68 318LA [Re: moparts]
Kid-Dart Offline
Loc: Michigan
Used 68 318 Intake to oil pan, casting date 7/18/68. Don't really know much about this motor it came in my sons Belvedere. going different direction and selling off parts. runs really good and starts all the time. the intake is worth at least $300 itself. he is looking for $900 or best offer. Can hear it run. No Headers or Carb just motor.
he is motivated to sell and is a young gun getting into the hobby.
MOTIVATED TO SELL!!!
Will ship at your cost.
PM us here
Thanks Moparts
Edited by Kid-Dart (04/11/18 01:54 PM)
74 Dart Sport Best to Date 10.82 in the 1/4
#2481535 - 04/12/18 09:21 AM For Sale: Comp Cam CL20-228-4 (cam and lifters) [Re: moparts]
vinnyd76 Offline
Loc: Macomb, MI
I have a brand new comp cam and lifters set that was purchased for some heads that I sold. I no longer will use this cam. The cam and lifters have never been removed from the comp cam boxes. The kit is CL20-228-4.
Price: $200.00
#2481985 - 04/13/18 01:23 AM Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts]
rob_dirt Offline
Loc: maryland
EDELBROCK STR 12 340 or small block cross ram intake if interested call 814 842 3490 ask for jim 2500 OBO
Edited by rob_dirt (04/13/18 01:25 AM)
#2483105 - 04/15/18 01:11 PM Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts]
junkyardmaxie Offline
Loc: OH
small block EDELBROCK single plane perf intake with special water neck 318-340-360 excellent condition $125 plus shipping
#2483118 - 04/15/18 01:50 PM 1970 340 engine [Re: moparts]
moparguy1941 Offline
Loc: Crystal Lake, Illlinois
Selling a 1970 340 short block with a set of 2.02 j heads. Block has been bored .020 at some point. Cylinders all look real good. Good start for a performance build. Located in Crystal Lake, Illinois. Asking $1000.
#2483251 - 04/15/18 06:07 PM Re: For Sale -CD-1 Daytona Sensors Ignition System [Re: moparts]
DusTed74 Offline
Loc: WI. U.S.A.
For sale. 1 CD-1 ignition for any makes or models. It comes complete with all you see in the photo.
Please contact me here if you have any more questions.
$425. for all including shipping to your door in the lower 48 state.
Ted
#2483340 - 04/15/18 08:31 PM NOS new Holley W2 Pro Dominator intake [Re: moparts]
B1duster Offline
Loc: NY
Never bolted down or modified with dual 4150 top and gasket. $699 plus shipping from NY 12569.
#2483360 - 04/15/18 09:05 PM Newer Holley carb 1850 [Re: B1duster]
cudacar340 Offline
Loc: Grosse Isle, Mi
Super nice, used very short time then pulled for engine swap. Lightweight Aluminum , shines great. Cost 325, great deal at 250
734-692-7151
Edited by cudacar340 (04/16/18 08:51 AM)
#2483779 - 04/16/18 04:58 PM Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
1970 cast 360 block. I had it sonic checked and it had fairly thick walls which is typical for the early castings. Nice shape, standard bore size. I don't need it and would like to free up the space. $300 for the block. I'm not interested in crating it up for shipping so you'll need to swing by and pick it up or have a buddy pick it up for you. I have a bunch of other SB stuff that I'll sell cheap or toss in for free. Trying to clean out the shop of the SB stuff.
#2484408 - 04/17/18 08:43 PM Re: For Sale - Small Block Engine - 2nd Quarter [Re: AndyF]
Hemihead2 Offline
Loc: Pa
1971 340 long block, std bore, stock bottom end, crank mains .020, 2.02 J-heads, stock T-Q intake. Disassembled- $1,800
1969 A-body A833 4 speed with matching bell-housing, great shape- $800.00
Edited by Hemihead2 (04/21/18 10:31 PM)
#2485672 - 04/20/18 02:42 PM Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts]
Loc: OH
mini high torque starter like new kept as a spare for race car dont need now good working condition $65. plus shipping
#2485681 - 04/20/18 02:56 PM Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts]
Loc: OH
excellent small block perf 340 intake [can also be used on 318-360 engines encluded is special water neck $125 plus shipping dirt cheap dont need
Page 1 of 2 1 2 >
25,253 Registered Members
188,915 Topics
95RON as a standand octane at the pump?
by mopar dave
Today at 10:42 AM
For those who can't get enough ... new Ramcharger
by KISSAlien
Today at 10:21 AM
8 years under a cover "Forever Young" Diego is back!
by Diego_Ted
Today at 09:51 AM
Need help identifying Mopar performance part number
by WHITEDART
Today at 09:45 AM
