charger cam sensor problem #2482477
04/14/18 10:45 AM
04/14/18 10:45 AM
pennsylvania
poboyengineering Offline OP
pennsylvania
HELP! 2008 Charger, 3.5L. The car will not start with the cam sensor plugged in. Unplugging it will allow the engine to start (long crank time, batch mode).
I've tried the original sensor and an aftermarket one, same symptoms.
Can someone enlighten me on what's going on?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: charger cam sensor problem [Re: poboyengineering] #2482512
04/14/18 11:56 AM
04/14/18 11:56 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
How many miles? Maybe a suspect timing belt? I don`t know too much about it to help but I was just thinking out loud.
Re: charger cam sensor problem [Re: poboyengineering] #2482563
04/14/18 01:27 PM
04/14/18 01:27 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Tell us everything you touched. What was the reason behind the sensor swap also?
Re: charger cam sensor problem [Re: poboyengineering] #2482568
04/14/18 01:34 PM
04/14/18 01:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Replace it with a mopar brand sensor. There seems to be a lot of trouble with the aftermarket brands.
Re: charger cam sensor problem [Re: poboyengineering] #2482664
04/14/18 06:02 PM
04/14/18 06:02 PM
pennsylvania
pennsylvania
I took the intake off to replace the plugs. Gennie units, 165,000 miles. I got everything working (it was a tow in) but this weird sensor deal. going to the dealer on Monday to get the sync done.
