Re: Dropping a 360 magnum into my 70 b body few question
[Re: 79machocharger]
#2485615
04/20/18 02:22 PM
04/20/18 02:22 PM
Andrewh
There is actually a guy selling the factory aftermarket efi kit for magnums. at 2200, not sure if it is worth it or not, but it comes with everything you need. I guess it was for the carb crate engines. durango/dakota forumns. don't have the link handy. http://www.dakota-durango.com/forum/showthread.php?t=458698
#2487712
04/25/18 11:17 AM
04/25/18 11:17 AM
Posts: 5,443 ME
79machocharger
ME
So I bought the cam snout extension from Hughes so I can run the v belt set up and mechanical fuel pump and correct fan. How hard is it to switch over? Do I need a timing belt cover off of a la style 360 or will a la 318 work as well. I’ have a couple of la 318’s kicking around that I can rob all of the pulleys from and brackets for alt and power steering.
[Re: poorboy]
#2488226
04/26/18 01:06 PM
04/26/18 01:06 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
If you wanted to keep the magnum EFI, its hard to beat the Hot Wire harness. At just over $1,000 it is a stand alone harness that requires 4 wire to be connected for use. There are also wires supplied inside the harness for connecting to gauges and other options. www.hotwireauto,com I've used 3 Hot Wire harnesses, one 5.9 Magnum (into 2 different vehicles now) and two 5.7 Hemi and they work well out of the box. Gene This is sooo true. I love my Hotwire Harness. I also love the SCT handheld tuner and custom tunes from a competent tuner. My 5.9 Magnum based 408 spins out nearly 500 hp & 630 ft lbs of torque at the crank. That coupled with a 3800 stall converter, a 200R4 4 speed automatic w lock-up converter, 3.91 gears and Nitto Drag Radials make my 3700 lbs '68 get up and boogie.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
