Re: Repairing cluster circuit board... feasible?
[Re: vinnyd76]
#2481653
04/12/18 02:37 PM
04/12/18 02:37 PM
Posts: 21,063 Niles , Ohio
therocks
Niles , Ohio
I fixed a pin on my 65s dash.One was snapped off.I used a hollow pin from a used old IIRc light plug from a car.had to manipulate it a bit but it worked for at least 15 years.Long before you could buy remade parts.Rocky
Chrysler Firepower
[Re: MoparMike1974]
#2481864
04/12/18 10:33 PM
04/12/18 10:33 PM
Posts: 2,087 New Mexico
JMCFAN
New Mexico
can they be soldered in??
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: vinnyd76]
#2481908
04/12/18 11:44 PM
04/12/18 11:44 PM
Posts: 294 Maryland
MoparMike1974
Maryland
Yes but the solder will likely crack. I usually swage and solder them. I have a spare dash sitting here. I will replace all the pins and see how it goes. It looks like I have the correct pins. Once I verify all the dimensions I will post a part number and show you where to get them. I do have the correct tool to do these and would be open to offer a service for those wanting it done correctly.
[Re: vinnyd76]
#2481950
04/13/18 12:52 AM
04/13/18 12:52 AM
Posts: 294 Maryland
MoparMike1974
Maryland
Im posting a link to the pins but only with a warning. If you try to crimp these with anything but the correct die, you risk cracking the pcb. https://www.mouser.com/ProductDetail/Keystone-Electronics/1226?qs=%2fha2pyFadugZeT54asEH3%2feiqU9vwWhq2ggPafz4ZTg%3d
I cant get a hyperlink to work so your gonna need to cut and paste her.
[Re: vinnyd76]
#2487970
04/25/18 09:20 PM
04/25/18 09:20 PM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
moparmike1974 nice work how much do you get for fix a board?
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
