My Combo so far, except intake manifold-prob. use a 6.1 #2481260
04/11/18 08:47 PM
04/11/18 08:47 PM
State College, Pennsylvania
fatman Offline OP
fatman  Offline OP
This is going in my 70 CUDA, which will see a fair amount of test n tune track time. Early 5.7 block, Molnar crank and rods 4.08, 6.125. Wiseco 3.94 piston with 0.866 pin, -5cc dish. Lightly ported Eagle heads, 11.1 compression. Howards 222/233 .582 .582, 114 cam. TTI 1.75 6.1 headers, 3 inch X pipe exhaust. 727, 3.73 Dana. MS3 FI. Not much data out there on the Edelbrock intake, but Dave Weber said on a Facebook post he doesn't like the PCV design and issues it creates. Kinda frustrating because there isn't much else I can do to find power. Last decision will be throttle body size and type, that's about it. Opinions welcome ! -scott
Re: My Combo so far, except intake manifold-prob. use a 6.1 [Re: fatman] #2481496
04/12/18 09:48 AM
04/12/18 09:48 AM
Bowling Green, KY
BlakDak71 Offline
BlakDak71  Offline
Bowling Green, KY
6.1 will be more than enough for what you're doing.
If you wanted to get fancy you could use a 6.4L SRT active intake to give it a little more grunt down low.
Re: My Combo so far, except intake manifold-prob. use a 6.1 [Re: fatman] #2481515
04/12/18 10:36 AM
04/12/18 10:36 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Good combo, 6.1 Intake will be fine, Curious question for you, do you have sonic #s after the 4.08 Bore? the 05 5.7 I had bored out to 4.09 cracked #1 thrust side after 5k mile(street miles).
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: My Combo so far, except intake manifold-prob. use a 6.1 [Re: ric3xrt] #2481528
04/12/18 11:06 AM
04/12/18 11:06 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I think the 4.08 he is referring to is the stroke. Molnar makes 4.08 crank. 3.94 is the bore
Re: My Combo so far, except intake manifold-prob. use a 6.1 [Re: fatman] #2481531
04/12/18 11:15 AM
04/12/18 11:15 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Just reread it and I did skip over "Wiseco 3.94 piston with 0.866 pin, -5cc dish" for some reason I thought his stroke was 3.795 with a 4.08 piston.
Re: My Combo so far, except intake manifold-prob. use a 6.1 [Re: fatman] #2481674
04/12/18 03:13 PM
04/12/18 03:13 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
sounds almost exactly like an 392 apache, very similar compression, cam, heads, CID, have you looked at a low miles take out engine?
The apache intake is better flowing out of the box plus it is plastic so light weight and keeps the air and fuel way cooler and as mentioned has the variable intake runner length. Last but not least they are cheaper. The only advantage of the 6.1 is it can be ported but its gonna need quite a bit to beat the apache intake and still going to put a ton o heat in the intake air. Another one thats better is the eagle truck intake and they are cheaper yet.
Re: My Combo so far, except intake manifold-prob. use a 6.1 [Re: fatman] #2481720
04/12/18 04:39 PM
04/12/18 04:39 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I have an eagle truck intake, the active part on the back is missing though... but would sell it cheap if you need one.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: My Combo so far, except intake manifold-prob. use a 6.1 [Re: Silver70] #2481816
04/12/18 08:34 PM
04/12/18 08:34 PM
fatman Offline OP
fatman  Offline OP
Thanks all, couple of questions. Wouldn't a truck intake horizontal throttle opening present a height challenge connecting a intake tube/air filter ? Is there comparison data available for 6.1 vs. 6.4 car vs. 5.7 truck intakes ? Thanks again!
Re: My Combo so far, except intake manifold-prob. use a 6.1 [Re: ric3xrt] #2482267
04/13/18 07:05 PM
04/13/18 07:05 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I might have gone with more compression....What fuel do you have available at the pump?
Re: My Combo so far, except intake manifold-prob. use a 6.1 [Re: ric3xrt] #2482291
04/13/18 07:58 PM
04/13/18 07:58 PM
Renton Washington
Triple Threat Offline
Renton Washington
Did you sonic check yours? My 04 5.7 block has a min thickness of .176 @ 3.93 bore. I wouldn't want to take it to 4.090, but 4.055 would probably be alright to still be over .100 everywhere.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: My Combo so far, except intake manifold-prob. use a 6.1 [Re: Triple Threat] #2482454
04/14/18 09:43 AM
04/14/18 09:43 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Block check @ 3.917 had .207 before bore .120 after Bore in that spot,(middle depth #1)
Thinnest spot on that block after bore was #7 non Thrust @.101 middle depth
Re: My Combo so far, except intake manifold-prob. use a 6.1 [Re: fatman] #2482540
04/14/18 12:52 PM
04/14/18 12:52 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Good combo except your 6.1 headers.
Factory headers are good but long tube are better.
Matt
Re: My Combo so far, except intake manifold-prob. use a 6.1 [Re: MattW] #2482637
04/14/18 04:28 PM
04/14/18 04:28 PM
fatman Offline OP
fatman  Offline OP
The headers are TTI long tube.
