rooster comb #2480757
04/10/18 09:52 PM
04/10/18 09:52 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Have 67 904 transmission with a 1 pin neutral safety switch,want to put the trans.in a 1970 car which is wired for a 3 pin switch,can I take the rooster comb out of 727 that is for the 3 pin style and put it in the 904,thanks
Re: rooster comb [Re: 426lloyd] #2480795
04/10/18 10:46 PM
04/10/18 10:46 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
You could just change the whole valve body
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: rooster comb [Re: 426lloyd] #2482739
04/14/18 09:28 PM
04/14/18 09:28 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
A single pin switch grounds the starter relay in neutral and park. A 3 pin switch does the same through the center pin and turns on the reverse lights as it closes the circuit between the 2 outside pins.
" The last official act of any goverment, is to loot the treasury" George Washington
