....thinking out loud, "if I ever get a chance to wrap my hands around the neck of the Engineer who designed the Emergency Brake cable setup connection point" The only way to replace a new cable setup is to take off the complete clutch pedal assembly !!?? The bolthead that holds the C-bracket in place should be turned around. Am i missing something here?
Still looking for LM29H1B415501, '71 Demon 340
