Building a quiet, low restriction exhaust for a big block
#2478612
04/07/18 12:58 AM
04/07/18 12:58 AM
Posts: 10,200 Someplace you aren't
SomeCarGuy
Starting to rework a 77 d150 with 440. I’d like a quiet ride, close to modern exhaust standards. That is without the modern cost. I looked on rock auto and for example a new age challenger muffler is like 1k-1500. Yikes.
That model 440 is pretty much a dog so I can’t be corking it up with restrictions to accomplish this unless I want to play little engine that could going up hills.
Thinking I’ll have the manifolds to start, as it has so many needs and I also dont want to capture the starter. I just don’t have the time I used to for taking all sorts of extra stuff off for simple repairs. Even if a set of headers is available that doesn’t capture, the cost would hurt things like getting a paint job.
Will run an x pipe as that has always suited me.
First thoughts are big mufflers and then also use a can type one near the back. That should cut out a drone, not sure it will be quiet enough. I could try a second set of mufflers before the cans, but would that be the ticket? Real estate might be a problem to since it all has to run down the pass side.
Will finish with repop road runner/super bee tips out back.
I want my fair share
Re: Building a quiet, low restriction exhaust for a big block
[Re: SomeCarGuy]
#2478624
04/07/18 01:11 AM
04/07/18 01:11 AM
Posts: 8,392 Highland, MI.
Sunroofcuda
Highland, MI.
Mufflers, then some resonators downstream. Use 2.5" pipes.
[Re: SomeCarGuy]
#2478641
04/07/18 01:32 AM
04/07/18 01:32 AM
RapidRobert
I used some cheap parts house "cherry bomb" glasspacks as the only muffs on a truck DD. they worked but did get louder over time. In their favor was that they did not neck down where the end nipples are welded to the main case & the louvers were punched outward, both for no restriction. In your case I would get the longest pair I could find or even 2 pair of em with or with out some dynomax regular type muffs. best would be a quiet restricted system with some electric or vac or cable cutouts right at the header collectors, not cheap tho & would be quiet when you need quiet & loud only when you want it.
[Re: SomeCarGuy]
#2478696
04/07/18 06:03 AM
04/07/18 06:03 AM
Posts: 4,848 Memphis
HemiRick
Memphis
I just put some 2.5" $40 stainless mufflers on my 5.0 Mustang that fit your description perfect....they are essentially glass packs but are not straight thru they are rectangular and the pipe is offset from one side to the other as it goes thru the muffler. They are not loud, but have a nice sound. https://lmr.com/item/JES-MF1236/Jones-Max-Flow-Performance-Muffler
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: SomeCarGuy]
#2478702
04/07/18 06:21 AM
04/07/18 06:21 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I think my old '73 Power wagon used dual 2.5" offset inlet, center out turbo style mufflers mounted side-by-side with the inlet on the low side and center up higher before going over the rear axle. It was not really loud, but you could still hear it.
My '86 W100 with a 318, I think used 2" flare at manifolds that up sized to 2.25" right after the manifold connection, then used (I think the brand was IMCO?) chambered muffler and I think it was a 3" in, 2.25" out, but we mounted it backwards with the 2.25", and a single 3" out, over axle and exiting under the bed side behind rear wheel at a 45 degree angle, end cut parallel (45 degree) to the bed side. Not sure if that hurt flow, but it made a near stock 318 sound pretty good.
There are 3" in, and 2.5" out mufflers that might work good reversed. It sure makes a simpler install with just the single 3" tailpipe.
[Re: SomeCarGuy]
#2478725
04/07/18 09:17 AM
04/07/18 09:17 AM
Posts: 5,777 ohio
ruderunner
ohio
I used the Jones mufflers on several vehicles and love them, nice and quiet with minimal restrictions. I think they discontinued the unpolished version so plan to spend a few bucks more.
I also agree with the dual inlet single outlet idea, just way easier. You won't lose any performance from that.
Angry white pureblood male
[Re: SomeCarGuy]
#2478731
04/07/18 09:40 AM
04/07/18 09:40 AM
SomeCarGuy
Thanks guys, lots of stuff I haven’t used or heard of to research.
I do want a dual exit look though.
[Re: SomeCarGuy]
#2478736
04/07/18 09:56 AM
04/07/18 09:56 AM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
What kind of power are you talking? If you are talking a stockish 1977 440 and you want quiet, you don't need 2.5" dual exhaust. The best driving, snappiest throttle, best pulling 440 I ever had was a factory original 350 hp 440 in a 67 Chrysler. It had a 2.5" single exhaust.
If you are like most, and simply must have an exhaust system that is 50% bigger than you need, get a dual system with 2.5" headpipes, necked down to 2.25" mufflers and 2.25" tail pipes. Get the longest full body muffler that will fit from Midas. This is basically what the factory used on the highest hp 440 it offered. This will support an honest 375 hp.
I've made over 400 hp with that system with a DynoMax full body (25.5" long) 2.25" Super Turbo muffler (17747).
In the future you can step up the muffler and tail pipe size to 2.5" and easily support +450 hp.
[Re: SomeCarGuy]
#2479082
04/07/18 10:07 PM
04/07/18 10:07 PM
Posts: 20,751 A collage of whims
topside
A collage of whims
The Dynomax "Super Turbo" seems to be the best-flowing of that style, has flow directors at the inside ends & doesn't neck down inside. Good crisp sound, not boomy, very livable with tailpipes. A buddy ran a pair of Imperial mufflers on a SB Chevy PU and it was quiet, about like a stock dual exhaust from the '60s. Ran stronger than stock. I'd go with 2.5" downpipes if the manifold flanges accept them, H or X pipe, 2.5" mufflers, 2.25" tailpipes to the rear corners.
[Re: BSB67]
#2479182
04/08/18 12:57 AM
04/08/18 12:57 AM
SomeCarGuy
In the future you can step up the muffler and tail pipe size to 2.5" and easily support +450 hp. 2.25 would cut some sound, but hymn me in for future upgrades. Both engine rebuild and just adding headers. Kinda a curious response. Dyno tests of back to back same engine with just bigger exhaust shows you gain power everywhere with larger pipes that the myth holds as “being bigger than you need.” Also guys like ray evernham will tell you to step your exhaust size bigger as you go. A bean counter will tell you it’s “good enough” for what your doing if you can cut a few cents out of a trillion cars and make packaging easier on an assemble line. There really is a lot to be gained by putting on a big honking exhaust. I can think of a couple cars it really stood out on after switching what should’ve been an ok setup. I just have never one together with being quiet as part of the package. Some things came out fairly tame, others roared. Last car I did ended up with a drone around 2500. Sold it before I got around to trying resonators.
[Re: SomeCarGuy]
#2479210
04/08/18 01:59 AM
04/08/18 01:59 AM
Posts: 4,669 Wichita
GY3
Wichita
I've done Dynomax Super Turbos and Ultra Flows on different cars. Both worked really well.
Ultra flow with 3" pipe is what I run now.
[Re: SomeCarGuy]
#2479274
04/08/18 10:28 AM
04/08/18 10:28 AM
BSB67
Prospect, PA
In the future you can step up the muffler and tail pipe size to 2.5" and easily support +450 hp. 2.25 would cut some sound, but hymn me in for future upgrades. Both engine rebuild and just adding headers. Kinda a curious response. Dyno tests of back to back same engine with just bigger exhaust shows you gain power everywhere with larger pipes that the myth holds as “being bigger than you need.” Also guys like ray evernham will tell you to step your exhaust size bigger as you go. A bean counter will tell you it’s “good enough” for what your doing if you can cut a few cents out of a trillion cars and make packaging easier on an assemble line. There really is a lot to be gained by putting on a big honking exhaust. I can think of a couple cars it really stood out on after switching what should’ve been an ok setup. I just have never one together with being quiet as part of the package. Some things came out fairly tame, others roared. Last car I did ended up with a drone around 2500. Sold it before I got around to trying resonators. Maybe its how you look at the tests. I usually don't see the same. And tests are usually done with higher hp applications. I have track times and dyno info to support it all. If you think your at 450 hp now, and what to go to 600, go bigger. The 2.25 will be noticeably quieter than the 2.5". I've gone high 12s at 109 in a 4250 lb car with 2.25" mufflers The Engine Master engine exhaust testing pretty much supports what I have learned. In that test the 2.5" system gave up like 15hp over a 3" system on a 600 hp+ engine. What is your power level, 250 ish?
[Re: BSB67]
#2479515
04/08/18 05:16 PM
04/08/18 05:16 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
What you are looking for in that 440 isn't in the exhaust. You need to remove any smog equipment, add a good carb. a torque cam and converter, proper rear gears. Add some compression and your GOLDEN.
You want quiet? Go stock replacement. Bigger may be sound like more fun, but isn't necessary for your needs. Same for fancy mufflers. Stock replacement will work fine. That 440 should have loads of torque on tap. That's what your looking for, right? You can do a y pipe in front of the rear axle for the dual look you want. It won't help performance though. Any competent muffler shop should be able to accommodate you.
I have mechanical Aptitude. I can screw up anything.
[Re: SomeCarGuy]
#2479673
04/08/18 10:58 PM
04/08/18 10:58 PM
Sunroofcuda
Highland, MI.
20" bodied Dynomax Super Turbos. Don't use "stock" mufflers.
[Re: SomeCarGuy]
#2479724
04/09/18 12:13 AM
04/09/18 12:13 AM
SomeCarGuy
I’d like to look at it up on a rack and lay the system out. Might be hard to stack anything other than bullets, so solution might be a y pipe into a single big muffler and split from it.
[Re: SomeCarGuy]
#2479755
04/09/18 01:08 AM
04/09/18 01:08 AM
SomeCarGuy
Anybody try a Flowmaster 50 or 70 series on a big block? I got to thinking about 20 years ago I put a system of theirs on a 94 f150 5.0 and it was quiet. Believe it was a force II and it had a 70 series. Pretty hard to compare a single pipe on a 302 to this deal. That and I sold that truck 15 years ago so I can’t remember exactly how it sounded.
[Re: SomeCarGuy]
#2481111
04/11/18 02:41 PM
04/11/18 02:41 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
Where are you at? I've got a pair of Flow Master 70 series mufflers that have never been installed in the rafters of my garage. They're huge. 2.5" inlet/outlet that are both off center.
[Re: SomeCarGuy]
#2481447
04/12/18 02:29 AM
04/12/18 02:29 AM
SomeCarGuy
I’m in cincy. I don’t have the truck to see how much room I have under there. It’s getting rubber parts replaced at a shop and a general going over.
Have considered I might have to do a y pipe and maybe split at the muffler. Suppose I could run a faux tip to get the look, seems a hokey thing to do.
